Offroad & 4x4
is it worth doubling
Old Jan 23, 2007 | 10:24 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
i have a 96' f150 with a 5speed and a np208 right now, i want a little more gear so i thought i might get a np203/np205 doubler, i was wondering if it was worth buying the doubling kit or just mount the divorced 205 behind the 208
any comments are apreciated.
Old Jan 23, 2007 | 12:23 PM
chrono4's Avatar
chrono4
well, with 13'' of lift, I'm just going to guess this isnt any rock crawler. What axle gears do you have init?
Old Jan 23, 2007 | 12:33 PM
fishmanndotcom's Avatar
fishmanndotcom
if you dont need low low range then no! thats for those who want to go very slow without wearing a clucth or overheating an auto!
now if you wanna have it for the cool factor and for some extra gearing options and you dont mind the work and spending the cash go for it! i'm not gonna tell you to spend money but i think just about anyone who goes offroad could benefit. heck i'd love to do it in my powerstroke b/c i could get it way way low and backed with the 7.3L I could just about pull the foundation out from under a building! it'd also help with backing trailers, i could get off the clutch. and i would be lengthening my drivetrain to have a shorter rear shaft and longer front shaft!
-cutts-
Old Jan 23, 2007 | 01:19 PM
quadzjr's Avatar
quadzjr
its not 13" of lift anymore, it will be somewhere around 25-30" on tractor tires, with rockwells, so 6.72 gear ratio, just for the mud
i would like low range, but isn't it the same thing if i locked the 208 into low then locked the divorced 205 into low as well. which would be lower the 203/205 doubler or the 208 and the divorced 205
Old Jan 23, 2007 | 01:26 PM
MBBFord's Avatar
MBBFord
I don't know if or how you could set up a divorced 205, but any way
A 208 and 205 both in low range would be about 4.6:1
A 203/205 double would be alittle under 4:1
There is a new kit out that you can get 3:1 low range with a 205 to....
Old Jan 23, 2007 | 01:49 PM
quadzjr's Avatar
quadzjr
thanks MBBford for the calculations, i really dont want to spend 1000 dollars just to make the double, not even the t-cases
ill just make a mount for the 205 behind the 208 and use the stock jack-shaft between them, which would help with my driveline angles, it just sucks i have another tcase just sitten there, its kinda a rig but is better than spending a grand
Old Jan 23, 2007 | 02:41 PM
god.boots's Avatar
god.boots
25-30" of lift!!! ive got to see this.
Old Jan 23, 2007 | 02:57 PM
quadzjr's Avatar
quadzjr
theres def. a lot more with some of the other peoples trucks i play with
Old Jan 23, 2007 | 04:26 PM
god.boots's Avatar
god.boots
and for what reason will a 20+" lift benefit you off road?
Old Jan 23, 2007 | 05:05 PM
quadzjr's Avatar
quadzjr
to clear 53" tractor tires!!!
but thats beside the point anymore advice from yall's expeirences would be nice, anyone ever atempted such a thing?
Old Jan 23, 2007 | 05:32 PM
god.boots's Avatar
god.boots
i know for a fact you dont need that much lift to clear thoes tires. thats what the sawzall is for!
Old Jan 23, 2007 | 06:32 PM
fishmanndotcom
you could try and talk some sense into ppl but you would never get anywhere!
i've seen ppl run 53" XL's with rockies and 6" of lift.
whatever floats your boat (or truck )
-cutts-
Old Jan 23, 2007 | 06:53 PM
whitefordaward's Avatar
whitefordaward
I really wont to see this 25+ lift and see how okied up it is.I'm 6"1 and a 18in lifted p-stroke puts the running bords at the center of my chest.he must have a sky crane in his driveway to get in it.
Old Jan 23, 2007 | 08:28 PM
jcg82's Avatar
jcg82
Well if its going to be mud you are playing in. I myself wouldn't really see the need for really low gears. Just my 2 cents.
Old Jan 23, 2007 | 09:39 PM
quadzjr's Avatar
quadzjr
first of all, theres no fender trimmin, its still a very nice truck,
its easy to get in just grab the step side, climb the v-tread, and step on the step side.
another reason for the lift is to stay high and dry, im not to put my engine under mud.
yall should really check out the trucksgonewild dvd, thats some of the folks i ride with, those trucks easily have 25-40" of lift
im guessin nobody else has any comments about my t-case question.
