351c Timing Chain Play
Old Jan 22, 2007 | 09:30 AM
Kongslibakken's Avatar
Kongslibakken
How much play in your Timing chain is to much I have about 1/2". If I change out the set anything special I need to look for?
Old Jan 22, 2007 | 04:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
1/2 inch where?
Old Jan 22, 2007 | 09:00 PM
Kongslibakken
I measure 1/2 inch of slack in the chain between the gears. I checked out the dist when I move the timing gears and I turn about 1/8 inch before the distributer moves. I'm thinking this should be OK but the motors out and on the floor. Just trying to cover all of my bases.
Old Jan 23, 2007 | 02:31 AM
grclark351's Avatar
grclark351
slack is measured when all the slack is on one side of the gears. rotate the crank so that the timing chain pulls tight on one side. then place a straight edge against the slack side of the timing gears, and push the slack of timing chain with a ruler. you are now measuring the slack.
is the cam sprocket aluminum and have nylon around the outside teeth? is the nylon chipping and coming apart?
Old Jan 23, 2007 | 07:41 PM
Kongslibakken
Ok I measured the slack with the straight edge maybe 7/16" of play no there is no nylon and nothing is coming apart.
B00M3R
Apr 5, 2015 11:32 PM
1999 expedition
Jan 12, 2015 09:31 AM
ander129175
Oct 9, 2014 02:54 PM
Bob Lawhorn
Feb 4, 2005 02:34 PM
KJKozak2
Jul 4, 2003 09:42 AM
