4R70W issues
Old Jan 20, 2007 | 07:09 PM
jetfiremuck's Avatar
jetfiremuck
4R70W issues
98 Mountaineer 60k. I just bought from a friend with 5.0 2wd. The trans hangs onto the 2-3 shift. I have to let up on the gas completely to get it to shift sometimes. When it does shift,either the 3-4 shift occurs or TCC locks up immediately.
So.
I pulled the valve body and found the 1-2 accumulator lower spring broken, the 3-4 accumulator spring retainer and spring dropped out when I dropped the valve body. It is not a snap ring just a plate with 3 legs that sits in the bore cutout in the trans housing.
2. I replaced the shift solenoids,tcc solenoid and a new epc solenoid. I checked the shift valves and springs in the valve body all move ok. I am waiting for the gaskets and spring from the dealer. Have I missed anything ? Is it possible that the 2-3 accumulator spring retainer and spring would cause a shift delay? The 1-2 shift was ok even with the broken spring. I opened the old shift solenoids and found no debris. The trans fluid was ok.
Old Jan 27, 2007 | 10:34 PM
jetfiremuck
Update. I replaced the solenoids ,new 1-2 and2-3 accumulators, new spring and cleaned and checked valve body for debris. New valve body gaskets 3 intotal., drained converter. Running and shifting like new. Factory workshop maunual makes it easy,parts approx $140. If the trans fluid is not burnt most problems from my research appear to be solenoid or valve body related which can be fixed without trans removal. A good set of ramps available from walmart in heavy plastic for $40 and an inch pound torque wrench. Just my experiance
jdog771
Jun 30, 2016 11:02 PM
Decipha
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
13
Mar 3, 2015 08:47 AM
Prototypemech
Dec 24, 2013 10:05 PM
KooLaid
22
Nov 15, 2012 08:49 AM
jetfiremuck
Jan 29, 2007 03:59 PM
