Aerostar Ford Aerostar
1992 aerostar rear ABS light
Old 11-03-2006, 02:00 PM
flo's Avatar
flo
flo is offline
I would like to know how I can turn off this light I checks the brake and one of the adjustment cable was broken replace it and the light is still on help please
Old 11-04-2006, 12:49 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
The most likely cause is corrosion in the master cylinder causing a short in the sensor switch for the shuttle valve. It is screwed into the front of the master cylinder. Pull it off and clean out the corrosion, and it should clear the problem up.
Old 11-04-2006, 01:41 AM
copper_90680's Avatar
copper_90680
copper_90680 is offline
Hi Flo:
Welcome to our FTE forum
Old 11-04-2006, 06:24 AM
flo's Avatar
flo
flo is offline
thanks will work at it to-day will let you know end result
Old 11-04-2006, 10:27 AM
flo's Avatar
flo
flo is offline
it work clean it and voila thank you so very much i how you one
Old 01-21-2007, 04:58 PM
flo's Avatar
flo
flo is offline
thank you very much
Old 01-22-2007, 10:09 PM
xlt4wd90's Avatar
xlt4wd90
Flo,
You're welcome. Glad to see you fixed your problem.
hail destroyer
07-07-2017 08:58 AM
gdkaufman
11-18-2016 04:15 PM
melvinew2
06-30-2016 08:48 AM
Larietpsd
2015 - 2020 F150
04-14-2016 10:47 PM
aparamburo
2004 - 2008 F150
12-15-2012 09:52 AM
Quick Reply: 1992 aerostar rear ABS light
