non operational gauges
Old Jan 19, 2007 | 06:32 PM
chapinjeep13's Avatar
chapinjeep13
Talking non operational gauges
have no idea why the gauges in my diesel centurion bronco dont function. the speedometer and boost/turbo temp gauge do work. i thought that the all must not function for the same reason but i dont know . also someone suggested a ground but i dont know where that ground would be located. thank for any help
Old Jan 19, 2007 | 07:27 PM
Beast12's Avatar
Beast12
Thread moved to Electrical/Wiring forum.
Welcome to FTE! I am sure someone will be along shortly to help. Enjoy the site.
-Matt
Old Jan 19, 2007 | 10:06 PM
Franklin2's Avatar
Franklin2
What year is this vehicle?
Old Jan 20, 2007 | 07:45 AM
chapinjeep13
its a 1993 f350 chassis/cab
Old Jan 20, 2007 | 07:22 PM
Franklin2's Avatar
Franklin2
Did you checked all the fuses? If they are all good, I would take the cluster out and clean it up and check the connections and the circuit board.
Old Jan 21, 2007 | 11:44 AM
daveengelson's Avatar
daveengelson
Suggest checking to see if you have an instrument cluster regulator. Not sure on later models, the 61-66 have instrument cluster regulars, small metal box in appearance mounted on the back of the panel. Regulates constant voltage 5-9 to instruments.
Old Jan 22, 2007 | 02:40 PM
chapinjeep13
thanks i will see if the connections are clean, but i cant find any info in chilton manual about regulator
Old Jan 22, 2007 | 04:44 PM
Franklin2's Avatar
Franklin2
The later models did not have a regulator. I am not sure when they changed it, but I would guess the late 80's, maybe 87.
PEZLO
25
Mar 8, 2017 01:06 PM
fyredude
Jul 20, 2016 12:21 AM
glennemay
1983 - 2012 Ranger & B-Series
40
Jul 4, 2015 05:28 PM
jrockdiddy
May 15, 2015 05:47 PM
tbart16
Apr 19, 2007 03:22 PM
