Power Drain
Old Jan 19, 2007 | 06:29 PM
wyldeman's Avatar
wyldeman
Unhappy Power Drain
I have an 02 F350 crew cab. the day time running lights quit operateing around a yera ago and the door locks also. i Asked the Ford house and they said that it was some computer that has gone out???? well now my door locks will not work from the door and now the remote doesnt work either. i here a clicking up under teh dash but cant make out where it is comming from. I had to pull the 30AMP fuse for the door locks because it keeps trying to open the locks.( i lock it minutes later it unlocks it self) Then today the horn started beeping short blasht every now and then. So now i pulled the horn fuse. the past 3 days i have had to jump it off in the morning( has new batteries less than 6 months old). Please help thanks in advance!!
you can reach me at ole_floorman@yahoo.com
Old Jan 19, 2007 | 06:39 PM
Franklin2's Avatar
Franklin2
On a 2005, there is a "body security module" that controls the locks. It also is tied into the horn and the headlights.
The manual lists a "body control module" as being mounted on the lefthand rear of the cab. I am guessing it's the same as the security module.
Old Jan 19, 2007 | 06:42 PM
wyldeman's Avatar
wyldeman
"body control module" on the left side ( passenger side) . Is it a small plugin type or some smalll computer??? Thanks for the reply
Old Jan 19, 2007 | 06:46 PM
Franklin2's Avatar
Franklin2
When you order anything from the parts store, or are looking in manuals, left and right are referenced to the driver sitting in the seat. So left would be the driver's side. I would imagine it's a little black box with lots of wires.
Old Jan 19, 2007 | 06:47 PM
wyldeman's Avatar
wyldeman
that might be the computer they where talking about?
Thankx
Ill try that in the morning .
Old Jan 19, 2007 | 07:02 PM
wyldeman's Avatar
wyldeman
Do you think that would be under the truck or behind the back seat? Trying to narrow it down a lil.
Thankx Dave
Old Jan 19, 2007 | 10:13 PM
Franklin2's Avatar
Franklin2
Behind the back seat, midway up the back wall.
jdhill95
21
Apr 30, 2016 02:02 PM
Mrs. Mojo
Aug 17, 2010 02:10 AM
cliffaz780
Jan 6, 2010 05:06 PM
cochran226
Sep 9, 2007 08:42 PM
Mr. Whiskers
Electrical Systems/Wiring
Jan 10, 2004 08:26 PM
