Do I need sway control?
Old Jan 19, 2007 | 01:43 PM
lo's Avatar
lo
I want to pull a 2500# travel trailer with my 2000 F350 SuperDuty (single rear wheel). With a tongue weight of 250 lbs, I won't need weight distributing, but will I need sway control?
Old Jan 19, 2007 | 05:14 PM
sltrrco's Avatar
sltrrco
no I don't think so
Old Jan 19, 2007 | 06:21 PM
twayneb's Avatar
twayneb
Sway bars are for when you have a long or heavy load that can put torsion forces on the tow vehicle You have lots of weight in the F-350 so the trailer will have little effect on it.
Old Jan 19, 2007 | 07:57 PM
Gparcels's Avatar
Gparcels
You should be fine, I pull a 6000lb load without anything done to the truck. No problems at all.
Old Jan 20, 2007 | 05:30 AM
campin' nut's Avatar
campin' nut
Won't even know that it is there.
Old Jan 21, 2007 | 10:26 AM
jim henderson's Avatar
jim henderson
You don't need WD hitches or Sway, but in my experience they WILL make your drive less fatiguing since you won't fight your rig as much.
Sway control is mostly for winds and when you pass a big truck. Those trucks can really suck a trailer sideways.
The WD hitch just helps make sure your rig rides level and in my experience the ride is less jouncy.
Your tongue weight BTW should be closer to 15%. 10% is a bit light and makes the trailer a bit squirrely.
Also make sure the weight of the trailer is the actual versus "stripped down" mfg rating. Accessories, toys food water etc add up fast. Your trailer may weigh more than you think. 2500 pounds is an awfull small travel trailer I think. Is it a tent or popup or is it all Aluminum or just really short?
My experience with short trailers is that they can be more squirrely than a long one. The long trailers are more prone to getting pushed by the wind or a big rig.
Like I said, No you don't need them, but they will make your rig far less "twitchy" and you won't be making constant steering corrections etc. You ain't lived until you get fishtailing, fun. A sway control drastically decreases the odds of that happening.
Good luck,
Jim Henderson
Old Jan 21, 2007 | 01:02 PM
RVDave's Avatar
RVDave
I pull a 8,500 # (confirmed weight), 30' travel trailer with my F150. I do not use a sway bar nor do I think I need one. I trailer follows real good. Yes semi's have an effect, sometimes, but not enough to add a sway bar. As I understand it, you cannot back with a sway bar, but will have to remove it first. My dealer recommended a sway bar ONLY if I had problems. A friend we camp with uses a sway bar and swears by it. Personally I think he has weight distribution issues.
Old Jan 22, 2007 | 10:24 AM
jim henderson
Depending on the design, you can back up with a sway bar. I do it all the time. I used to have to back up for over 1000 feet up a slight hill. You can backup in a tight turn. The sway bar just makes a lot of popping and groaning noises. Probably would be easier to loosen it up before backing, but I never think of this when I am doing it.
You should not use a sway bar when the road is slick. The manual says this can cause the rig to go sideways. For reference, I have an Eaz Lift WD and sway system.
I do notice a difference in the amount of steering corrections with and without the sway bar. On long trips 500miles +, I am less tired if I use the sway bar.
Just my experience,
Jim Henderson
Old Jan 22, 2007 | 11:40 AM
lo's Avatar
lo
Thanks for the response. It's a 16' travel trailer (Fun Finder X 160). I think you all are right about the sway control. With all the junk I put in the back of the truck, I think the trailer would have a hard time wagging it. I can always turn the trailer brakes on to stop the sway.
Old Jan 22, 2007 | 03:26 PM
DeepDoc1's Avatar
DeepDoc1
There may be some kind of antisway bar you need to remove while backing, but my DrawTite (owned by Reese) has zero issues backing. Never have to remove it until I unhitch. I've had the trailer nearly 90 deg while backing without problems. I have a small 8x10 snowmobile trailer I use for general hauling that I don't use wd or antisway on, but I wouldn't leave home without it on my 26' TT.
Kafn8td
All Things Towing
Jun 11, 2014 07:18 AM
eaglebqh
2009 - 2014 F150
Sep 12, 2011 08:37 PM
fordquist
Dec 16, 2008 05:48 PM
damone
All Things Towing
Mar 26, 2004 04:53 AM
jetjock16
All Things Towing
19
Dec 27, 2003 09:15 AM
