Sway Control versus WDH
Old Jun 10, 2014 | 09:28 AM
Kafn8td's Avatar
Kafn8td
I've recently added a weight distribution hitch with sway control (Blue Ox). I noticed that if I turn off the electronic sway control on my '14 250, I get less sway.
Is it possible that they are counter acting each other?
Old Jun 10, 2014 | 04:13 PM
senix's Avatar
senix
I moved this down to the towing section for more input.
Old Jun 10, 2014 | 04:37 PM
Kafn8td's Avatar
Kafn8td
Thanks senix.
Old Jun 10, 2014 | 05:16 PM
senix's Avatar
senix
I think the truck anti sway is not working well with the blue ox anti sway myself.
I would use the blue ox over the trucks.
Old Jun 10, 2014 | 06:15 PM
BossGasser's Avatar
BossGasser
You really shouldn't be having any sway to start with.
I suggest that you go back to square one -
Level the trailer when it is hitched
Weigh the trailer
Weight the tongue
etc...........
Old Jun 10, 2014 | 07:07 PM
RV_Tech's Avatar
RV_Tech
There are multiple things that can cause sway and not all are easily diagnosed. Your report of increased sway with the truck's system is not unknown and has appeared in other forums on FTE in the past by my recall.
I would suggest reviewing your set-up and then using only the Blue Ox system or the truck's but not both as I would expect they will fight one another.
My two cents worth,
Steve
Old Jun 11, 2014 | 07:18 AM
Kafn8td's Avatar
Kafn8td
Thanks RV Tech.
intofire56A
2015 - 2020 F150
Sep 19, 2018 12:54 PM
NWRVR
All Things Towing
Apr 19, 2016 07:00 PM
guthrie&co
All Things Towing
Nov 16, 2006 11:01 PM
jetjock16
All Things Towing
19
Dec 27, 2003 09:15 AM
