fuel tank replacement
Old Jan 19, 2007 | 11:08 AM
txlegman's Avatar
txlegman
What is the difference other than the obvious between a tank that has roll over protection and one that doesn't? Are they interchangable?
Old Jan 19, 2007 | 11:48 AM
LxMan1's Avatar
LxMan1
I believe that roll over protection is just a check valve in the vent line. What year vehicle are you refering to?
Old Jan 20, 2007 | 09:08 PM
txlegman's Avatar
txlegman
Sorry 1978 F100, step side. I replaced the tank. The original had a check valve on the top center. The replacement did not. The inlets for the two rubber filler hoses were reversed with the large opening being on the left instead of the right and the small opening is on the right. So far no problems. Ran a full tank of gas through it.
timpage
27
Aug 10, 2016 10:53 PM
swampthang
Mar 3, 2014 12:49 PM
bcaughhorn
20
Feb 2, 2011 07:39 PM
PATS2002
Jan 2, 2003 09:06 AM
parr4
Apr 8, 2002 06:17 PM
