Power steering stiffness
Old Jan 19, 2007 | 08:45 AM
Unimog005's Avatar
Unimog005
ok...first of all, I repaired (rebuilt) everything in the PS system to stock....new pump, lines, and a rebuilt piston on the drag link.....about 2 or 3 years ago, and it has been functioning great.....until recently. I've begun to notice "stiffness" in the steering espectially on extreme right turns, but it seem to happen both directions, sometimes at rev, sometimes at idle and it seems to happen in both directions.....
It feels like the belt is loose, but I have tightened it twice and it has the proper deflection and I hear no squeaking from it.....does the PS fuilid need to be dumped and system flushed from time to time? Or is my pump or piston wearing out?
It seems like I noticed this issue first right after I got it back from the shop....they had replaced the water pump and intake manifold.....the belt seemed a little loose and i tighteneed it...but this problem still persists, to the point were I do not feel like I have PS at all sometimes....
Old Jan 19, 2007 | 09:17 AM
jowilker's Avatar
jowilker
Is this a 4X4 truck?
John
Old Jan 19, 2007 | 09:36 AM
Unimog005's Avatar
Unimog005
oh yes....sorry, I just figure you guys know already....lol
1967 F-250 4x4 "Highboy" with 390 engine and Mated np435/np205 Tranny/T-fer package from 77-79 model era.
Old Jan 19, 2007 | 11:35 AM
jowilker's Avatar
jowilker
Hey No problem bro, there is only 384,000 registerd users of this site, so keeping up is a piece of cake.
John
Old Jan 19, 2007 | 07:01 PM
72 high boy's Avatar
72 high boy
Talking
i have much learning to do myself, and i don't know much about that type of p/s system. i would first look for leaks and check fluid level, if that checks out then i would suspect the pump might be developing problems. i think that if the cylinder was bad it wouldn't produce entermentant problems, rather it just wouldn't work and it be leaking like a siv. or if it did work it probably wouldn't be very effective, but consistant.
these are just my thoughts and the course of action i would take if it were my situation.
Old Jan 19, 2007 | 07:56 PM
Unimog005's Avatar
Unimog005
I've checked the fluid several times and it's always at level....and there are no apparent leaks. I am leaning towards the pump being worn out (seems early for that) or possibly a developing problem in one of the hoses.
There is one hose on the control valve that gets rubbed by the nut on the actuating arm that comes off the steering box.....I already had it wear through the original hose that was there...the new one has a plastic guard (that rides up all the time) but I suspect it may have some sort of "crushing" damage that is impeding the fluid flow....
I guess I'll just wait for it to break and hope the snow is gone before I have to lay on the groud to replace it! lol
Old Jan 20, 2007 | 12:40 PM
Hypoid's Avatar
Hypoid
I'm leaning toward pump, although I don't know if there is a proportioning feature incorporated in the control valve. Was a filter added with all the new equipment? How does the fluid look, can you see through it?
ON EDIT: Have you tried greasing the ball joints and steering linkages? Makes a big difference with my armstrong steering.
Old Jan 20, 2007 | 12:54 PM
Unimog005's Avatar
Unimog005
there's no filter in the system that I can see, the fluid is still clear when I check it...not to say there isn't some sludge someplace....the shaft of the piston get's pretty dirty being exposed as it is. I will try the grease though.....I know last time I was under there to do the front end, I stopped at the driveshaft as it had no zirc fitting any longer....I paused to laugh and never finished up....
AndreVR
Apr 15, 2014 09:14 PM
BBDC
Aug 30, 2010 12:07 PM
mark b
Oct 29, 2008 05:59 PM
speedrdr
Apr 15, 2007 03:24 PM
Ford4me302
May 26, 2005 05:36 AM
