Magnaflow Recommendations
Old Jan 19, 2007 | 07:45 AM
dustykingranch's Avatar
dustykingranch
Okay, I am getting ready to pull the trigger on a Magnaflow exhaust for my new '06 King Ranch supercrew. I am trying to decide between the Magnaflow dual side exit (front of tire) or the single rear exit (behind the tire). Anybody have an opinion on which is better and why? Thanks!
Old Jan 19, 2007 | 10:29 AM
F-250 diesel's Avatar
F-250 diesel
what about duals out the back?
but if those two, i would get the duals that exit in front of the tire...looks better than a single pipe IMO
Old Jan 19, 2007 | 01:34 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
I'm all for the dual side exit. We have them here on our site at MotorHaven http://motorhaven.autoanything.com/exhausts-mufflers/20A50221A1.aspx?kc=MOTORH
Old Jan 19, 2007 | 04:49 PM
05 F-150 SCAB's Avatar
05 F-150 SCAB
I have the duals that exit out the front of the tire, i went with it because it looks good,and because i wanted something different then just the duals out the back..
Old Jan 19, 2007 | 05:58 PM
Ferguson65's Avatar
Ferguson65
I have the standard magnaflow SISO in mine. I wouldn't change it at all. Everyone has duals out the back anymore, and I don't want to deal with exhaust when hooking the trailer up. I would wonder if the interior noise level would be higher with the exit in front of the tires. I assume it would.
Old Jan 19, 2007 | 10:43 PM
DASTUD's Avatar
DASTUD
I have an 06 king ranch and i have the SISO MAGNAFLOW and love it. Sounds great as well.
Old Jan 20, 2007 | 07:36 PM
Bob Jusnes's Avatar
Bob Jusnes
As far as performance they will both be about the same, its all up to you on which style you like better!
Old Jan 20, 2007 | 08:05 PM
vochy's Avatar
vochy
I have an old F-150 with dual side outs behind the tires and like it. I wouldn't put side outs in fornt of the tires because the exhaust makes the wheels look like crap. I have seen this on the newer body style lightings and other stock 97' f-150s, single out pasenger side infront of the wheel and that wheel is always in bad shape. A roomate of mine in college had a 97' F-150 with the side out in front of the wheel and it corroded that wheel badly. Also your in the cab noise level will be significally higher.
Old Jan 21, 2007 | 10:25 PM
deisele75's Avatar
deisele75
If you love the sound of a V8, then you have to get duals of some kind. The harmonics of duals is totaly different than single exhaust. Try to imagine one person singing alone, then two people singing in unison.
I recomend duals; Where they exit is up to you.
