I am looking to get a programer/tuner that will calibrate for tire size read codes,possibly have diffrent levels of power to choose from,give the most bang for the buck.Any help would be great
with this you can pull codes run test and some time this month or in febuary you will be able to do some recalibrating for the speedo and other things... you can also do live readings...you also get on line help to use this tool...when you click on this link look at the top of the page..click on forum..then scrole down till you see AutoEnginuity
you will not find a tuner that will reset you speedo for tire size..
They do make a tuner to change the speedo for tire sizes. I think its a hypermax tuner. If you got some money you can do the best combo out there. Fix the speedo with an accuspeed/truspeed. Buy Autoenginuity, which is the best scan tool you can buy, then (i have not done this part yet) buy a DP tuner.
