programers
Old 01-18-2007, 11:15 PM
jays power stroke's Avatar
jays power stroke
jays power stroke is offline
programers
I am looking to get a programer/tuner that will calibrate for tire size read codes,possibly have diffrent levels of power to choose from,give the most bang for the buck.Any help would be great
Old 01-19-2007, 02:17 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
with this you can pull codes run test and some time this month or in febuary you will be able to do some recalibrating for the speedo and other things... you can also do live readings...you also get on line help to use this tool...when you click on this link look at the top of the page..click on forum..then scrole down till you see AutoEnginuity
you will not find a tuner that will reset you speedo for tire size..
http://www.itpdiesel.com/store.php?crn=135&rn=426&action=show_detail
Old 01-19-2007, 10:44 AM
John311t's Avatar
John311t
John311t is offline
They do make a tuner to change the speedo for tire sizes. I think its a hypermax tuner. If you got some money you can do the best combo out there. Fix the speedo with an accuspeed/truspeed. Buy Autoenginuity, which is the best scan tool you can buy, then (i have not done this part yet) buy a DP tuner.
Old 01-19-2007, 11:02 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
You will not be able to reset for tire size with any programer... I dont know why but none of them do it...
I just got my AE software... there better not be an upgrade already... DAMIT!
Old 01-19-2007, 04:44 PM
ron's power stroke
no there isnt an upgrade just yet but will be soon..you will down load it on line when its ready...
Old 01-19-2007, 08:00 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Jay released 4.4.1 the other day. Accelerator pedal position volts now shows up.
and Torque converter comanded and actuall were renamed to Torque converter slip desired and actuall.
There are rumors that version 5 will be able to recal the speedo and several other dealer functions but nothing solid yet.
Old 01-20-2007, 05:47 AM
ron's power stroke
where do i find this?? does it down load with out the AE disk??thanks alan..
