good flow thru exhaust and intake always helps a gasser,
then some power adders will give you a 30 hp boost (maybe SCT)....
and what about something like a supercharger/turbo....
what is that one you can add to the end of your exhaust and plumb back to the engine ? www.ststurbo.com/ ?
is a supercharger worth the cost if you dont build the motor to handle that torque upgrade..i read another post on here where a guy had his 10er charged and eventually (cant remember exact mileage) somehwere under the 150k range..his motor grew tired and gave up..rods, pistons, valves...??
