need some help please
Old Jan 18, 2007 | 04:58 PM
dixiemudder04's Avatar
dixiemudder04
i have a 94 f150 with a 302 efi. My problem is, sometimes when i push on the gas i have this rattling noise. It sounds like something small rattling. It does it real good when im going up a hill. When im on the gas(not to the floor just normal) and it starts rattling, i can let off the gas and it stops. I dont know what it is but daddy's does the same thing. And he has a 94 with a 302 efi. Is this commom on 302 of this year model?
Old Jan 18, 2007 | 05:02 PM
ubereal2's Avatar
ubereal2
Talking Several thing
This could be several things.
Most likely you have a timing issue. Could also be bad fuel, and a hot (overheated) engine will also do this.
Best guess is you're timing is off.
Bob
Old Jan 18, 2007 | 07:20 PM
dixiemudder04
but the check engine light came on today stayed on for about a minute and went off. My oil pressure is running at the "A" on normal. The charge was good and the temp was at the line before Normal. Daddy said that that could have been my o2 sensor. i was thinking maybe it was something in the cat rattling?
Old Jan 18, 2007 | 07:22 PM
HemiEater's Avatar
HemiEater
Plug it in............. Plug it in.....
Old Jan 18, 2007 | 07:23 PM
ubereal2's Avatar
ubereal2
Smile
Still leaning towards you're timing. You need to put a timing light on it and see where it's at. If anything if you don't have a timing light, advance, or retard you're timing just abit. Then drive the truck again and see if it help's.. Or made it worse.
Bob
Old Jan 18, 2007 | 07:35 PM
HemiEater's Avatar
HemiEater
Do you and Dad get your gas at the same place....................?
Old Jan 18, 2007 | 09:45 PM
muddman's Avatar
muddman
Ya know I've owned 6 fords in my years, pleased with ford, and one of the biggest things that I've had problems with rattleing is the center piece on the stick shift. the first time it started rattling it took about 2 hours for me to figure it out.
Old Jan 18, 2007 | 10:03 PM
arctic y block's Avatar
arctic y block
Sounds like spark knock to me. Play with the Timing like they said.
Old Jan 19, 2007 | 05:52 AM
dixiemudder04
no not all the time. It doesnt sound like spark knocking. i've heard what spark knocking sounds like. Its like a piece of metal rattling. But it dont do it all the time
Old Jan 19, 2007 | 06:00 AM
HemiEater's Avatar
HemiEater
could be an exhaust leak, I've seen a noisey lifter become a exhaust leak .......
Old Jan 19, 2007 | 06:02 AM
HemiEater's Avatar
HemiEater
With the engine light coming on i would get to Auto Zone and have them plug it in and see why the light came on. they should do it for free.......
Old Jan 19, 2007 | 10:28 AM
Kemicalburns's Avatar
Kemicalburns
your cat converter is shot. i have this very issue on my 88 bronco. thought it was pinging (not), thought it was exhaust leak (not). smacked the cat with a rubber malet and discoverd the exact sound. look into a bassani Y pipe with hi flow cat and be done. good luck
Old Jan 19, 2007 | 11:01 AM
dixiemudder04
if its the back cat i'll just cut it off or gut it. then run me a flowmaster. with 45* turndowns
Old Jan 19, 2007 | 02:33 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
Kemicalburns is right, go for the Bassani Y to stomp this one out http://motorhaven.autoanything.com/exhausts-mufflers/61A2673A0A0.aspx?kc=MOTORH
Old Jan 19, 2007 | 04:10 PM
HemiEater's Avatar
HemiEater
would a rattling cat turn the engine light on??
