Sponsored by: Auxito
add daytime running lights?????
Old Jan 18, 2007 | 11:50 AM
jimm66's Avatar
jimm66
How do you add daytime lights? Does it just light the low beams? This would be for an 02 f-150. Any idea on cost? Was this an option in 02?
Old Jan 18, 2007 | 02:13 PM
03-F150's Avatar
03-F150
I have an 03 and don't have daytime running lights. It must have been an option. I didn't care then, but I am curious about getting it now, also. I hope it's just changing the lights switch. The dealer would probably charge a bundle for that part.
Old Jan 18, 2007 | 02:57 PM
73f350sc's Avatar
73f350sc
Why not just turn your lights on using your headlight switch?
-Chris
Old Jan 18, 2007 | 02:59 PM
EvinM's Avatar
EvinM
I have an F-150 XL that I did convert. I'm trying to find where I bought the parts...somewhere in TX I believe... $60 On the top of the dashboard passenger side you take off the top and take out a blank plug and insert a relay. Then you go to the driverside front lights and add a big resister. I'll look for more info.
Old Jan 18, 2007 | 03:09 PM
EvinM's Avatar
EvinM
http://www.geocities.com/skyjet1/DRL.html
Old Jan 23, 2007 | 06:01 PM
ls973800's Avatar
ls973800
EvinM, thanks for the link, as I am also thinking about adding the DRLs to my 2003 F150. The only thing I did not see was some type of sensor to turn the lights on to full power when it gets dark enough.
Did I miss that, or was that not included in that link?
Old Jan 23, 2007 | 08:02 PM
jimm66's Avatar
jimm66
I believe you have to turn them on unless you have the auto-on option. The drl's just light the headlights and not the tail-lights. If you have the option then you already have the sensor. I think it's on top of the dash.
Old Jan 24, 2007 | 09:54 AM
EvinM's Avatar
EvinM
When you are using DRL they turn on as soon as your truck starts. At night you turn on your nomal lights which are then at full power. So the only 2 items you need is the relay and resistor
Old Jan 24, 2007 | 10:05 AM
PilotRob's Avatar
PilotRob
-Chris
I like that idea. It's free.
Old Sep 21, 2011 | 01:07 PM
echo657's Avatar
echo657
-Chris
Because you eventually break the **** off...twice, lol!
CougarXR02
15
Apr 19, 2021 04:27 PM
Quest1
Escape & Escape Hybrid
Sep 26, 2014 09:45 PM
cracked block
1983 - 2012 Ranger & B-Series
Apr 13, 2014 06:34 AM
awright48
2009 - 2014 F150
Feb 16, 2014 08:13 PM
jasonlasvegas
Jul 5, 2004 11:29 PM
