Sponsored by: Real Truck
True locker
Old Jan 18, 2007 | 08:04 AM
top that's Avatar
top that
True locker
I have f350 dually with 3.73 rear looking for better traction any info on the true locker or factory L. S. Where to find and any down sides
Old Jan 18, 2007 | 08:32 AM
Maxium4x4's Avatar
Maxium4x4
Moved from the 6.0L forum to SuperDuty...... You will find a ton of information coming your way soon from the guru's here at FTE who love to play in the mud.
Old Jan 18, 2007 | 08:40 AM
Aggie007's Avatar
Aggie007
Factory LS, as it states is very limited. You can pick one up from your dealer around $260, and looking about $75-125 to get it installed, and its super easy.
Detroit has a soft locker which most people run. But like most lockers, you will have to get used to driving with a locked rear end, which isn't hard. Most say the Detroit has very good road manners and is impressivley quiet. I think they run around $600. This would be my first choice next to Auburn if I was going to install a locker.
Auburn has a bad *** limited slip, but cost around $700.
Also there is Powertrax which has two lockers, that are supposed to disengage around sharp turns. One is supposed to be noise less when it disengages. I think they are $250-350 for the two.
ARB has an air actuated locker, so you can lock up the rear end just when you need too. I don't like the idea of have to have an air supply and or the possibility of an air line failing. With everything you need you will spend more than $1000 on the set-up.
Old Jan 18, 2007 | 10:58 AM
chocLablimo's Avatar
chocLablimo
I jusr replaced my 2005 F-250 with 4.30 gears, replaced the bearings/races, and put a ARB locker in the front and the rear. I spent lots of time researching the Ford "mechanical" locker, and decised against it. Ford provides the limited slip technology to keep your truck going straight down the road whne you hit ice or wet, with a mechnaical locker it will get out of control.
Old Jan 18, 2007 | 11:46 AM
Ronin007's Avatar
Ronin007
Good discussion here on different options for you. It really depends on how you are going to be using your truck as to which option is better.
Old Jan 18, 2007 | 01:19 PM
bucky440's Avatar
bucky440
I've been looking for something for my 2004 Excursion. The Powertrac was never made for the Sterling 10.5 rear even though the catalog lists a number. I just got a Detroit Tru Trac having been told the Ford LS unit is junk. Cost me about $520 with free ship and bearings, just need the time to install it.
Question for you guys that have changed rears, the factory service manual says to NOT reuse the anti lock brake ring if removed, to get a new one. Any coment? I bet most people don't follow this and reinstall the old one. Is it necessary or does Ford need to sell more parts?
Old Jan 18, 2007 | 05:39 PM
chocLablimo
Guys - The LS (Limited Slip) is a great technology, and used in the right application, it works great. LS is used to provide power to the wheel that is slipping. In rain and ice this works to help guide the car through the slip. The LS is not made or designed to be used in off raod situations where you would need a posi setup. The best setup for both LS and posi is a locking diff. locked when you need it, like off-road, and un-locked for around the town.
Old Jan 18, 2007 | 06:02 PM
Antelope V-10's Avatar
Antelope V-10
It maybe great technology but the one Ford uses is no good. I have a TrueTrac now and get 2 wheel marks in the dirt and mud instead of one.
Old Jan 18, 2007 | 06:31 PM
dcf4x4's Avatar
dcf4x4
I think choclab was implying that the limited slip is NOT a severe duty locker. It is a general use traction device.
I like the LS, and it works just fine for what it was specifically designed to do (see choclab's post). I would not trust it in serious mud or 3 feet of snow, but then again, my truck would submarine itself and NO amount of locker would help in the deep gooey stuff.
Old Jan 18, 2007 | 07:16 PM
Ronin007's Avatar
Ronin007
This was all discussed in the thread I posted above. The factory LS is not junk if setup properly. Most people, including Ford put too much friction modifier in and therefore it does not work properly. Mine was one of the few that was setup correctly from the factory and worked great in all conditions including snow.
Yes a LS was not intended for true off road use, but can be used off road and can be very effective. Yes a true locker will out perform a LS off road, but I wouldn't just dump your stock LS without changing the amount of friction modifier in it first.
Old Jan 18, 2007 | 07:25 PM
99f350sd's Avatar
99f350sd
I've had the detroit for 3 years now. To be honest I hardly know its in there, even with 6000 lbs of sand in the rear. I would do it again for sure and I would put one in the front if they made it for the D50.
Dick
Old Jan 19, 2007 | 07:01 AM
ken75ranger's Avatar
ken75ranger
Hey, someone else that knows the trick to the Ford LS!
I should have known it would be a fellow NY'er. You guys might want to try it. It does work.
Old Jan 19, 2007 | 09:42 AM
ccerniglia's Avatar
ccerniglia
I Agree, I'm Very Happy with my LS Diff. Had my truck out in the snow last night (1" and very slick) and only engaged the 4X4 once: and that was because i stoped on a steep incline to pick up a friend and couldn't keep the traction in the rear. The Ford LS Does just what it was made to do.
Old Jan 19, 2007 | 11:54 AM
99f350sd's Avatar
99f350sd
Put 1 tire on snow or ice and the other on pave you won't go anywhere. They work ok when both tires have some traction. Thats not enough for me.
Dick
Old Jan 19, 2007 | 12:41 PM
Ronin007's Avatar
Ronin007
Again either too much friction modifier or just use a little brake and it will work. Dick I know you know how this stuff works. I just worry that too many people are junking their factory LS without either adjusting the amount of friction modifier in it or understanding how it works or could be made to work. I wheel with open diffs and have gone places that rigs that were locked front and rear could not go. The only way I do that is I know my vehicle and how to get the most out of it. The guys with lockers were driving like idiots which makes it easier for me too.
