Offroad & 4x4
Oba
Old Jan 17, 2007 | 12:00 AM
kjg26's Avatar
kjg26
Oba
i'm still slowly piecing together an on board air compressor system. I am about to order a pressure switch as well as a pop off safety valve. The pressure switch is a NON adjustable ON at 110psi and off at 150psi. The pop off valve is a non adjustable set at 150psi. Will the system trigger the pop off valve if i use this pressure switch. Does it blow AT 150 or above 150? Thanks
Keith
Old Jan 17, 2007 | 12:23 AM
captain p4's Avatar
captain p4
That's probably a little too close. What is your lowest rating for pressure in your system? I'd have at least 10psi below that for your safety valve and then at least another 5 below the safety valve for your cutoff on the switch.
Old Jan 17, 2007 | 09:33 AM
fishmanndotcom's Avatar
fishmanndotcom
you can try that, but i think it may be a lil close. i have my system to run 115psi and my safety valve pops at 120psi and sometimes when its real cold it'll pop open
-cutts-
Old Jan 17, 2007 | 01:11 PM
kjg26's Avatar
kjg26
all my system is rated for around 200psi. so i'll just get a 165pop off. thanks everyone.
tarkster
Sep 19, 2014 09:54 AM
tarkster
New Member Introductions
Sep 15, 2014 02:23 PM
keithm1961
Feb 27, 2012 07:03 PM
krs_med
Jul 12, 2011 11:42 AM
Saxon
Jun 9, 2005 03:12 PM
