I just spent half of the day attemting to install Warn hubs on my F350 come to find out the cap is very slightly too big at the base. The place purchased from neglected to ask if it was a dually. In total frustration, I have searched online for the part that would fit 2000 F350 Dually! I took these back this evening and he gave me another part number..I looked online at Warn and this part ALSO specifies not for a dually. Do they not make hubs to fit a dually??? I currently have MileMarker and they were crap too. Can anyone tell me what part it is I need. Thank you..getting very frustrated...
No, Warn does not make a hub for a DRW F-350.
I'm surprised you say the Mile Markers are junk. I've never had one but a lot of guys here swear by them. Which model do you have?
It appears Super Winch an option. Again, no experience with those.
Do yourself a favor and go to www.Warnindustries.com to buy a set. You can buy a very good set of hubs for around $200, and they'll never seize like the crappy Ford ones. The Ford OEM hubs list for around $540 a pair, and they'll just seize up on you or break like yours did, so you'd be much better off getting some from Warn. They're cheaper to buy, will not seize, and should not break. As far as I know they're warranteed as well.
Thanks! Unfortunately, they do not make them for F350 SD Duallys!
Redford,
Can you tell me the part number for the Warn? I am unable to locate it.
The MM's didn't last long. I believe I only had them for 3 years or a bit longer. There is not a part number on them and based on the info I found I bought the MM 449SS that should have fit but I tried to put them in last night and they didn't work. I thought maybe it was not aligning correctly but the old one slid right in. Any ideas????
I have always ran Warn hubs and thought I would give the MM hubs a shot on my '01 F-350 and I'm not impressed. They fit sloppy in the hub and the quality just does not seem to be up to Warn's standards.
