Aerostar Ford Aerostar
Speedo malfunction
Old Apr 14, 2007 | 11:43 AM
95awdmover's Avatar
95awdmover
Unplugging the abs module under the ash tray turned out to be the quick fix for the problem going to check the cluster circuit board next...
Old Apr 14, 2007 | 03:37 PM
99f350sd's Avatar
99f350sd
Well its about time..LOL .Don't bother its not that. I changed clusters and no change. Changing the tone ring helped alot but it wasn't dead smooth until I unplugged the abs module...I wish I knew whats going on...I'm gonna work on it more this summer..
Dick
Old Apr 14, 2007 | 04:00 PM
96_4wdr's Avatar
96_4wdr
ABS controller requires rock steady pure DC batt. voltage to pins 1,9 and 12
put a digital storage scope on these pins and monitor
you may have a failing alternator diode with AC output ripple on the DC or intermittnet fuses or wiring on those circuits that drops voltage on road impacts
may be failed RABS controller with shorted loading on an input from the DSS
there is a pinout resistance test for the ABS RABS controller but can not find it now....may be on the web
Old Apr 14, 2007 | 04:09 PM
99f350sd's Avatar
99f350sd
I swapped out the abs module NC...I will lookinto this again this spring...
Thanks for the tips.
Dick
myakkacracka
13
Jun 16, 2016 11:33 AM
patch2285
Nov 2, 2014 02:22 PM
myakkacracka
Mar 17, 2014 07:35 AM
hwm3
Jul 29, 2010 03:45 PM
Wiseguy150
Offroad & 4x4
21
Jan 22, 2006 05:12 PM
