Offroad & 4x4
Speedo
Old Jan 14, 2006 | 01:29 AM
Wiseguy150's Avatar
Wiseguy150
Speedo
Does anyone know what I will need to do to make my speedo work in my 95 F-150 if i swap to a 9 inch rear axel. Its a stick so the shifting problem is not an issue.
Old Jan 14, 2006 | 01:33 AM
ford390gashog's Avatar
ford390gashog
nothing. you will no longer have that feature
Old Jan 14, 2006 | 04:37 AM
first time 4x4's Avatar
first time 4x4
Could he swap in a trans-case off a 87-92 that has the speedo gear in it instead of the rear end??? Maybe, no way, I'm not sure?
Old Jan 14, 2006 | 12:00 PM
Wiseguy150's Avatar
Wiseguy150
Well this is great. I planned on doing the swap in March but if I can not have a speedo then there is no way I can do it because my truck will see a lot of road trips and high way driving. Much more on road then off.
Old Jan 14, 2006 | 12:35 PM
Wiseguy150's Avatar
Wiseguy150
If any one has any idea on a sollution or where I could find some good info on this problem at i wouild really apreciate it. Also i have heard that there is a Lincoln car called a versallies that had a 9 inch rear end with disc brakes so perhaps I should try to get one of those?
Old Jan 14, 2006 | 02:13 PM
tjc transport's Avatar
tjc transport
i ain't rite
the Versailles was Lincoln's version of the ford Granada. it came with a 9 inch, and disc brakes . the Granada ess also had that setup. i forget who makes it, but if you check with a speed/hotrod shop, there is a vss that works off of a sensor mounted to the driveshaft. this might work for what you have in mind.
Old Jan 14, 2006 | 04:13 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
ive seen people fab up tone rings and make the whole deal work on the net somewhere, s o i know it can be done...but its a heck of alot of trouble..
maybe find a sterling 10.25 with vss, and get a set of 8 lugs for the rear...itd be a good excuse to put a 1 ton setup in the front
Old Jan 14, 2006 | 05:33 PM
Wiseguy150's Avatar
Wiseguy150
If I were to go to the trouble of the steerling I think I would just go with a Dana 70 rear. Id still have a half ton frame so it wouldnt really be worth it. Plus I dont want to go to the trouble of leaf springs on the front. I dont know what VSS means nor do I have any Idea how a speedo works. Any site with some info that you know of would be great I have found little info.
Old Jan 14, 2006 | 07:21 PM
go_racing84's Avatar
go_racing84
It's not THAT hard to rig something up. I just did a google search for "universal speed sensor" . Check this out from Summit. Might be able to work with that.
Old Jan 15, 2006 | 03:34 AM
tjc transport
i ain't rite
VSS stands for vehicle speed sensor. it is an electronic device that is used in place of a speedometer cable and gear setup to send an electric signal to the speedometer head in the dash
Old Jan 15, 2006 | 04:49 AM
Wiseguy150's Avatar
Wiseguy150
Ok that makes sense then and aparently the 9 inch is set up with the cable set up like I think of when I think of a speedo. So it really shouldnt be to hard to make something work in that case. I deffinitly will want to keep the factory speedo working not add an aftermarket.
Old Jan 16, 2006 | 02:51 AM
Wiseguy150's Avatar
Wiseguy150
I talked to some one today that said the VSS is located in the transmition. If that is the case how does the rear end I have make a difference.
Old Jan 16, 2006 | 06:19 AM
JeremyH's Avatar
JeremyH
Wont that axle be too narrow for a truck? I know that folks put them into jeeps and the WMS/WMS is fairly close to stock, IIRC.
Old Jan 16, 2006 | 02:49 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
if it IS in the tranny it wont make any difference....except for gearing, if you get a different ratio with your new axle it will make your speedo inaccurate...and i dont know how to correct a VSS device....
Old Jan 16, 2006 | 03:27 PM
billybob_81067's Avatar
billybob_81067
Go check... if there's a plug with a couple of wires coming out of the top of your 8.8 then the VSS is in the rear end (I'm betting it is).
BUT if it's coming out of the tranny then that would make it much easier to swap.
Also to recalibrate your speedo there's a wire that you have to find under the dash and ground and then when you turn on your key you can recalibrate the speedo using a certain formula that you can find on the internet if you search for it.
