Motor Swap
Old Jan 16, 2007 | 12:19 PM
DangerRanger99's Avatar
DangerRanger99
Motor Swap
I am looking to get rid of the wimpy 3.0L in my 1999 Ford Ranger 4x4 and I was wondering what was the biggest motor I could put back into it without major drivetrain modifications.
Old Jan 16, 2007 | 12:29 PM
Tiggie's Avatar
Tiggie
Define drivetrain. If you are talking about the tranny and rear axle, I have the following advise: The biggest motor you can put with the current engine would be one based on a 3.0L. The tranny won't work with any other engine I know of, and the rear axle isn't going to like much more power.
If you are looking into an engine swap, I'd find a 4.0L Ranger/B-Series/Explorer/Mountaineer of the same year and swap the parts over. At this point, you are almost better off buying another truck. 5.0L Explorer/Mountaineer AWD swap could also be of interest, you'd be in the same situation of getting a complete parts vehicle.
Old Jan 16, 2007 | 12:32 PM
fordboy_52's Avatar
fordboy_52
if you want to swap anything it will take major modications including a new trans. the 3.0l is based on the taurus motor and it uses a one of a kind transmission.
Matt
Old Jan 17, 2007 | 10:53 AM
wendell borror's Avatar
wendell borror
If you want a project, do the 5.0 swap, James Duff enterprises has the 5.0 conversion kits. It this is you main mode of tranpertation, you would be better off trading for a 4.0 sohc ranger. Less involving and less expense in the end when you concider the rearend, tranny, odds and ends and the reliability factor.
Old Jan 17, 2007 | 06:55 PM
cj0606x's Avatar
cj0606x
I would go after a 4.0 V6 and tranny out of a 2003 or newer Ranger. They're rated at an impressive 207hp and after driving my dads quite a few times..I know it has plenty of gitty up. You wont be embarrassed at stoplight sprints.
Old Jan 18, 2007 | 05:26 AM
wendell borror
I reread your post and see you have a 4x4, so your diffs should be fine. You would a 4.0, tranny and computer. Not sure but maybe the 4.0 t-case and wiring harness as well. A wrecked doner truck would be ideal.
Old Jan 19, 2007 | 08:07 PM
DangerRanger99
Thanks
Thanks all around... I will be looking into all of these.
Old Jan 20, 2007 | 03:30 PM
lxtasy's Avatar
lxtasy
5.0 all the way.
That is what I have in my 92 ranger.
Actually, wanting to know BIGGEST YOU CAN DO?
I have seen 302 based , 351 based and even some BB based 429/460's in rangers. Depends on your budget.
