No Power When Towing Please Help.
Old Jan 15, 2007 | 09:58 PM
Delvac1's Avatar
Delvac1
Question No Power When Towing Please Help.
I'm new to this site and I am also new to diesel engines. I have a 2000 F-250 Crew cab, 4x4, 7.3 PSD. 6spd, 140,000 miles, No mods, no gauges (yet). I have had this truck for about a year and 1/2. And up until now I have loved it. I recently started a new job which requires me to use my truck. I tow travel trailers from New Orleans to Baton Rouge daily. Two a day. And ocasionaly from B.R. to hope Arkansas. When I'm not towing, the truck runs great, it will pass anything out there. But the second I put a trailer behind it, I can barely maintain highway speeds. I know how these trucks are supposed to pull. Thats why i bought it. There were a few oil leaks and I changed the o-rings that were leaking on some plugs inside of the engine valley. Not sure what the plugs are called. I changed the fuel filter, and air filter, I also run fully synthetic oil. I dont know very much about what makes these engines tick. So I'm not sure what else to do. Any help would be greatly appreciated.
Old Jan 15, 2007 | 10:10 PM
Uzumati's Avatar
Uzumati
To start with I would check for boost leaks. Make sure all 6 boots on the intercooler pipes and intake Y are clean and tight. the oild from the CCv has a tendency to seep out and can cause a leak.
Old Jan 15, 2007 | 10:32 PM
Bob Goodsell's Avatar
Bob Goodsell
Also check the turbo impeller. If the air filter was not seated, dirt might have eaten the impeller. To check, pull the boot off the turbo intake.
Bob
Old Jan 15, 2007 | 10:35 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Welcome to FTE. I would agree with Alan. Boost leak. Make sure to check all the boots. Better yet, pull them and clean them and do the CCV mod. Best way to check a boost leak is with a boost gauge. Do you have any gauges?
Old Jan 15, 2007 | 11:05 PM
Delvac1's Avatar
Delvac1
No gauges yet, what is the ccv mod?
Old Jan 15, 2007 | 11:17 PM
Tenn01PSD350
It is where the crankcase gasses and oil are routed outside the turbo inlet thus reducing the oily residue in the entire intake system is all but eliminated. When doing this, most clean/degrease the boots. Look for the link on 7point3.com
Edit: I did not find it there as quick as I would like. Do a search on the site.
Old Jan 16, 2007 | 06:53 AM
IDPisan's Avatar
IDPisan
Here is the link for the ccv mod
https://www.ford-trucks.com/forums/284862-ccv-mod.html
Old Jan 16, 2007 | 07:07 AM
hookd's Avatar
hookd
might as well do the 6637 filter and wicked wheel while your at it
Old Jan 29, 2007 | 06:26 PM
Delvac1's Avatar
Delvac1
Sorry it took me so long to respond. been working alot. anyway, tried everything you guys said, and alot more, finally just got fed up with it. I brought it to the stealership. Just got a call from them and they cant even find anything wrong. this is starting to get rediculous. I dont want to sell my truck but its looking like its coming down to that. Does anyone have any others ideas? It runs so good when its enpty, but if it cant tow I cant afford to keep it.
75Three90
Dec 19, 2014 09:57 AM
rmurphy
Ford Truck Parts for Sale
104
Dec 7, 2013 03:01 AM
kw5413
26
May 12, 2011 08:25 PM
shorebird
Jun 7, 2009 04:54 PM
lwhitley
New Member Introductions
Apr 21, 2005 04:59 PM
