anybody know of some type of crystals u put in water and u then put it in diesels, and is supposed to save u on gas mileage, soem guy was trying to explain it, he said with this thing u are at half throttle but have all the power as if u were at full throttle, i dont know what this thing is but if anybody else does let me know.
I have read a few sites talking about acetone in fuel to reduce the surface tension and leading to beter atomization of the fuel. Never tried it though. I did read where apparently it was fairly common in Southeast Asia and they had some bad experiences with the chemical reaction to gaskets, o-rings and seals to the point where it has supposedly been banned by government authority.
Being that I'm not a chemist (although I did stay at a Holiday Inn once. A long time ago. And I did abuse the mini-bar, but I digress) and I have never tried using acetone in a lawn mower engine let alone a real vehicle, and the only knowledge I have is what I have read, I wouldn't try it.
If you try this stuff on anything, I think you are rolling the dice.
I'm a certified Snake Oil salesman. Contact me if you want to buy a case of Snake Oil, or if you want more info. Snake Oil usually sells for $75 a case, but for a limited time I'll offer it to you for the low, low price of $50 a case.
is there anything out there cheap but will help u get a couple more mpg, my dad runs three fedex ground trucks and the company will reimburse u if your vehicle makes at least 10mpg, i think my dads is like 1 or 2mpg below
