Stuck Caliper Guide Pins, Help!!
Old Jan 15, 2007 | 07:17 PM
cvdenson's Avatar
cvdenson
Hey all,
Today I'm changing the pads. I started on the drivers side. Everything was going well until it came time to grease up the guide pins. I noticed they don't slide. I pulled the boots off and found that the pins are corroded into the caliper anchor plate and will not budge. This sucks because I can't even put the caliper back on with the new pads because the guide pins need to be in about a 1/4" or so.
Does this mean I need new anchor plates?
Chris
Early ’99 F350 XLT CC LB SRW 6sp
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Mods: Ford AIS w/Zoodad, CCV, SS Hpx, 3.5” DP, stock straight-pipe exhaust, Hutch/Harpoon, Oilguard, LUK clutch, Grill Gutter Mod, Ranch Hand rear bumper, Bridgestone Dueler A/T 285/75R16
<o></o>
Future Mods: 203T, ITP regulated fuel return, Coolant bypass, DP tune
Old Jan 15, 2007 | 07:43 PM
guzzle92's Avatar
guzzle92
If you can't pull the pins with heat or grunt, it's going to be time to get new caliper assemblies. Now would be a good time to upgrade from the early 99 to the current style. If your pins aren't moving, your brakes are not working.
I'm pretty sure the new ones are a direct bolt on.
Old Jan 15, 2007 | 08:00 PM
Muktown's Avatar
Muktown
mine were rusted so bad i had to heat the calipers up with a torch and bust the pins loose. it saved me the cost of a caliper. with some time on the wire wheel and a lot of anti-sieze and my brakes work great
Old Jan 15, 2007 | 08:20 PM
cvdenson's Avatar
cvdenson
Thanks for the quick reply Guzzle and Mucktown. So If I upgrade to the later style, do I only need the Calipers and Anchor Plates? And are the rears the same or did they change those in later models?
I appreciate your help!
Chris
<o></o>
Old Jan 15, 2007 | 08:42 PM
guzzle92's Avatar
guzzle92
Originally Posted by cvdenson
............So If I upgrade to the later style, do I only need the Calipers and Anchor Plates? And are the rears the same or did they change those in later models?.........
From what I can remember reading from previous posts, all you should need is the new calipers (complete unit). I have not updated an early 99 so you should wait until someone chimes in that had actually done the procedure that can coroborate the parts. I believe the rear calipers have also changed from the early 99s BUT DON'T TAKE MY WORD ON IT.
Old Jan 15, 2007 | 10:41 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I just had my front calipers replaced and they came with NEW slide pins and all new clips for the pads.
def get the newer 99+ newer calipers and pads
Old Jan 15, 2007 | 11:45 PM
guzzle92's Avatar
guzzle92
Powerstroke.com has the front calipers for $84 each (plus $60 core) that are listed for the 99 and up. Not sure about the rears as they are listed as 2000 and up model years.
Old Jan 16, 2007 | 03:42 AM
ron's power stroke's Avatar
ron's power stroke
i have an early 99..build date 3/98....just did all rotors and breaks front and rear...early 99 has 3 difernt rotors for the front..mine was the last one i tryed...one was over all bigger around..the second was just a touch too tall on the hub so when i tighten the lugs the wheel would bind..the 3rd is the one i wanted....they all took the same calipers and pads..i got my caliper at napa for 83.98..part # 242-4203...the rear caliper on my truck are the same both sides..one is mounted on the back of the rotor and the other side is mounted on the front side of rotor..so the calipers are the same right and left side...all calipers came with all new pins, clips and copper washers..when all done everything on my brakes are brand new...IMO chances are if your pins are that froze..the seals in the pistons are not much better..id get a new caliper
majestek12
Sep 16, 2015 02:06 PM
84espy
Apr 12, 2013 12:10 AM
westarms
17
May 26, 2009 07:38 PM
JimsRebel
Jun 8, 2008 10:16 AM
