largest tires
Old Jan 16, 2007 | 10:21 AM
Jakeman68's Avatar
Jakeman68
I am running 315/76/16 BFG mud terrains with a 2.5" add-a-leaf in the front. I am running an 8" wide wheel also. I had to do some slight trimming to the front bumper but less than an inch.
Old Jan 16, 2007 | 10:37 AM
gwebel's Avatar
gwebel
amiller93-
are those 305/75 or 305/70s?
Old Jan 29, 2007 | 07:00 PM
scottty's Avatar
scottty
Do they make a 305/70?
Old Jan 29, 2007 | 07:28 PM
nhancock's Avatar
nhancock
Scottty,
There are a few companies that make a 305/70/16. Go to tires.com and plug in the size.
Are you keeping factory rims? If not, you need to check the offset of whatever you're putting on. What doesn't rub on a factory rim may rub on an aftermarket due to the spacing.
When my truck was stock, I had 295/75/16's on factory rims w/ no rubbing.
With a 3" leveling kit, I rubbed a little with 305/70/17's on 17x9" rims. I don't remember the backspacing off the top of my head, but could probably find it if you're looking at rims. They were the Helo Maxx 8's.
Uzumati's Avatar
Uzumati
305/70R16 BF Goodrich All Terrains
Old Jan 29, 2007 | 07:37 PM
MAKO314's Avatar
MAKO314
I run 33-12.50r16.5 BFGs on eagle alloy 5809s and have no rubbing issues
Old Jan 30, 2007 | 03:01 AM
AustinS's Avatar
AustinS
I ran the BFG AT KO 305/70/16 last set with no rub stock height. There were none available when I needed new ones 2 months ago.
I guess they redesigned it a little and it has a slightly higher speed rating now.
I had to settle with BFG AT KO 295/75/16 this go round. I have to say they have 500lbs more capacity and are better in the white stuff, but they don't look as good .
The extra 1/2" makes a noticeable difference.
Austin
Old Jan 30, 2007 | 01:11 PM
fire fighter's Avatar
fire fighter
I put 35x12.5x17 on my 2000 SD F250 4x4 without any lifts. I had to heat and push in the rear inside of the plastic wheelwells about an inch. Other than that I did not have any rubbing. I did put the 35's on aftermarket wheels though. Could not put them on stock wheels without rubbing hard.
Old Jan 30, 2007 | 02:58 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Here's a pic of a Bridgestone LT305/70R16 on a 6 inch dually rim, they rub slightly on the Duraflap at full lock.
Moses2662
May 20, 2019 01:23 PM
Rudiak
Dec 9, 2017 08:52 AM
jmaddock
Mar 10, 2017 08:54 PM
psu927
Sep 23, 2016 09:55 AM
Chris Anchor
2009 - 2014 F150
Jan 29, 2009 07:37 PM
