I have a 1976 cab over service truck and had the regulator go out so the window drops when you shut the door. Does anyone know if the regualtors are the same for F100/F150/F250/F350/F500/F600/C600? I dont' have the truck available to me right now so I can't look to see whats really up. Thanks for any help you may provide.
Reason: spellin
The C-Series changed very little since the 60's all the way up into the 90's.
The same with the L-Series.
The only way I can tell the difference between a 1960's, 1970's, 80's-90's C-Series is by the name badges and dash. The 80's and 90's ones have the Ford Oval as example etc...
I believe these may still be avaliable from Ford Truck. If not a truck wrecker will definately have one. They may want to sell the whole door for it though.
Good Luck.
