Aerostar Ford Aerostar
97 Aerostar Timing Chain
Old 05-07-2007, 10:12 AM
ehawks's Avatar
ehawks
ehawks is offline
I have a scanner, assumed no check engine light meant no code but I will scan. Good idea about using it to find which one is misfiring. Will do.
Thanks
  #47
Old 05-07-2007, 04:26 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
make sure OBDII PCM is going into closed loop when coolant temp goes over approx 155d F
record fuel trim levels, primary O2 sensor voltage swing min>max
also record timing, should be 10 BTDC at idle and increase to 28 BTDC at 2k rpm
pull wire from IAC, engine rpm should almost or completely stop
double check to make sure all sensors are connected
the 2 scanners I have
http://www.autoxray.com/product_detail.php?pid=94
http://www.autoenginuity.com/products-scantoolpalm.html
clearing codes with a consumer retail reader or scanner does NOT clear the KAM in the PCM of faulty sensor readings or failed component operation, we only have the technique of disconnecting the neg-- batt. lead for 5 minutes to dump old KAM memory parameters
  #48
Old 05-07-2007, 08:41 PM
Aeroman59's Avatar
Aeroman59
Aeroman59 is offline
Originally Posted by 96_4wdr
97 has OBDII which continually monitors for misfires and stores same with snap shot in memory at time of event, will tell you which cyl is misfiring...can be injector, plug, wire, etc.
OBDII scanner is a cost effective investment for all newer vehicles...will pay for itself in just a couple incorrect repairs or wrong parts
the auto manuf.s have such a large investment in OBDII CAN and it works so well that it will be around for at least the next 10 years
I agree, a scan tool can save you lots of $$$$. If you get the ELM 327 chip, It will read most vehicles, there are quite a lot of software which will work with this scantool. Another good one is Autotap (am I allowed to mention that?). Most of these have software which will include a "digital dash" you can monitor most of the sensors on the engine. You can graph them & also you can record engine conditions while driving & play back later , if you take a recording device with you, (or even a stopwatch ) you'll be able to note when the misfire was at it's worse. Since fuel trim can also be graphed you can compare readings when this occured. Freeze frame is a feature which is a saved set of engine parameters, which the EEC records at the time a code is set, so that you get a snapshot of what the engine was doing at the time the code was recorded.
I've had one about 4 months & it is definately an asset & will pay for itself over a short time. You can also reset the CEL & better software will calculate Engine load & HP, long & short term fuel trims, RPM, MPH, ECT, ACT, PW (Injector pulse width), O2 sensor voltage, AFR Dilution (with wideband O2 sensor only), ISDC (idle speed duty cycle) throttle position, Ignition timing, etc. You could have already made use of it so far!
ATB Aeroman.,
  #49
Old 05-08-2007, 06:52 AM
ehawks's Avatar
ehawks
ehawks is offline
Got an 1443 Egr code this morning when I went out. Reset after the van warmed up and the code never came back for 17 miles. Will do more investigation and keep you posted.
  #50
Old 05-16-2007, 07:34 AM
ehawks's Avatar
ehawks
ehawks is offline
Okl, after tracing out the EGR system found that the one of the rubber hoses that connects to the carbon cannister (below the air cleaner) had fallen off. Hooked up and car ran great with no hesitation or missing for about 300 miles. Now i have a new problem. Daughter was driving the other day and when cold the idle was screaming like 2000 rpm. I unpluged the idle air soleniod and the idle dropped way down. Basicaly if you start it cold you now have to partially push the acccelerator down. Once it is warm it is fine. I was going to replace the idle air soleniod but thought I should check first. Is that a positioner or an open close valve? If it is a positioner I could understand how replacing it would fix the problem.
  #51
Old 05-16-2007, 12:40 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
it is a timed open closed valve that can be rapid variable timed opened by the PCM with variable timed DC voltage from the PCM
main stuck open failure is from dirt/PCV crud freezing piston
take off and soak in TB cleaner for an hour, often works and saves $$$$
also change PCV valve if older than 20k miles or loaded up with crud....do NOT try cleaning, the valve springs lose tension and the valve seat wears
  #52
Old 05-16-2007, 12:53 PM
ehawks's Avatar
ehawks
ehawks is offline
Yikes-$45 at autozone, yes I think I will pull it and soak it. Thanks for you help. I will let you know how it went. TB cleaner, you mean toilet bowl?
  #53
Old 05-16-2007, 01:48 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
throttle body cleaner
can of Berrymans B12 works also
only soak open valve end
do NOT soak electrical solenoid end
  #54
Old 05-16-2007, 01:49 PM
ehawks's Avatar
ehawks
ehawks is offline
Ah ha.
Thanks
  #55
Old 05-16-2007, 03:19 PM
copper_90680's Avatar
copper_90680
copper_90680 is offline
On some Ford IAC, the valve end can be separated from the solenoid. In that case, it becomes very simple. Just dunk the valve end alone.
I know that I can do this for my '95 4.0L, but not for the '93 3.0L. Maybe the '97 3.0L will be different.
  #56
Old 05-21-2007, 06:39 AM
ehawks's Avatar
ehawks
ehawks is offline
I acutually had problems on both my 96 AWD 4.0 and my 97 2WD 3.0. The 96 cleaned up well and worked. The 97 was shot. $45 at Autozone for a new one. Works great. Thanks for your help.
  #57
Old 05-21-2007, 10:12 AM
copper_90680
My God, what did you put in the gas tank?
wolgie
181
05-24-2021 10:23 AM
cixelsyd
1997 - 2003 F150
10-20-2016 10:31 PM
JOSEF150
2004 - 2008 F150
10-13-2013 04:06 PM
redrivergorge
11-02-2011 02:18 PM
pensacolaexplorer
10-26-2007 10:01 PM
Quick Reply: 97 Aerostar Timing Chain
