it started with a wierd drone at idle, today when i cruise at steady 50 i have 0 boost and egt is at 700 and it sounds like the ebpv is open or closed which ever it is like on a cold morning,
1. is it something to fix quick b4 some bad damage?
2. is it easy enough to fix on my own?
3. I will be going to the desert this friday so i need to tow is better no to?
4. would it be worth taking to a shop since im on short time?
I noticed the same thing with my truck the last couple of days. Except it was happening aroung1300-1400 rpms, not matter what speed. I figured it was because its been below freezing though. Your in cal though so its probably not that cold.
if i apply throttle i get boost, everything runs normal its just when i get to 50-55 mph and cruise there my boost goes away and it sounds like the ebpv is closing.....so more throttle i get boost stay there and no boost per the boost gauge
Yeah, disable the EBPV.
Now this new droning sound: something has to be letting that sound out. I would take everything apart on the intake side until you find the hole.
what would I do with out you, thanks fo the pic I read somewhee else on how to do it, (it was your post actually) the pics are even better help thanks!!!!
