hello from canada
Old Jan 14, 2007 | 06:25 PM
travis wright's Avatar
travis wright
Unhappy hello from canada
can somebody out there please please hook me up with an oasis report for my 03 f450 [6.0] as i did not learn of the potential problems with these trucks.I just brought this truck up from Indiana,and it smokes alot after start up and at idle when warm [greyish white]
Old Jan 14, 2007 | 06:32 PM
CanadaGuy's Avatar
CanadaGuy
Just post or PM me the VIN.
Old Jan 14, 2007 | 07:04 PM
travis wright
the vin# is 1FDXF46P23EC36273. thanx eh!
Old Jan 14, 2007 | 08:32 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Check out tsb 06-2-13 and see if it fits. Go to top of page look for recall/tsb. go to full text tsb .
Old Jan 15, 2007 | 06:03 AM
CanadaGuy's Avatar
CanadaGuy
I'm not one to send out an OASIS report, but what I can tell you is that it had headgaskets replaced in September, an oil cooler replaced in February, ICP sensor, glow plug relay and one fuel injector replaced in 2005, and a hydraulic pump problem back when it was new. It looks like it's been a bit troublesome.
Old Jan 15, 2007 | 08:20 AM
travis wright
well big red because i just bought the truck and only logged 200 miles i do not have much of a baseline,the only symptons i can verify is the excessive smoking,and hard starting[first turn of the key,it fires for 2 seconds then dies then takes another two or three 20 second turns before starting and running fine as far as i can tell except lots of smoke.I also had seperate issue with the electric fan engaging and disengaging[sounds like a siren]at hwy. speed.
And thanx for the oasis info Canada guy,Im sure it will prove helpful.
P.S Can anyone recommend a reputable service department in the Kitchener,Ontario Canada area
Old Jan 15, 2007 | 09:11 AM
TinyOne's Avatar
TinyOne
TravisThere is a good dealer in Woodstock. 403 Hwy at Wayne Gretzky Parkway.
Name fails me right now. They do a lot of deisel sales and have had good reports about them. If you ever get to Niagara Falls Brock Ford IMO is the best in the area for diesels. Its a long way but check it out if you are ever in the area.
Old Jan 15, 2007 | 06:27 PM
CanadaGuy's Avatar
CanadaGuy
That almost sounds like a glow plug issue. Does the smoke have a very strong raw fuel smell to it?
Old Jan 15, 2007 | 06:50 PM
travis wright
yes it has a strong fuel smell
Old Jan 15, 2007 | 06:53 PM
CanadaGuy's Avatar
CanadaGuy
It may be just that. On the passenger side rocker cover (or somewhere in that area if it has been moved to install a hydraulic pump) is a silver module, about 5 inches long with a green connector and a black connector... Sometimes the connectors come loose. Might be worth a try to see if that's all that is going on.
Old Jan 15, 2007 | 06:58 PM
travis wright
I will try that in the morning and post my results.
Is that dealership in brantford [hwy.403 & wayne gretkzy
Old Jan 15, 2007 | 09:12 PM
TinyOne's Avatar
TinyOne
Sorry Travis. Brantford.
Old Jan 15, 2007 | 10:22 PM
rtoy's Avatar
rtoy
Brant County Ford.....Lynden Rd & Wayne Gretkzy Parkway...... (519) 752 7858......Ô¿Ô
Old Jan 16, 2007 | 08:39 AM
travis wright
thanks for the info.I will call today
