Demmer 375 Steering Box ?
Old Jan 14, 2007 | 09:01 AM
sstrlh's Avatar
sstrlh
I have a 65 4x4 that i think has a demmer 375 steering box. I would like to find one to rebuild to save the down time of remove & rebuild. Anybody know what years these came in that would be a direct bolt up.
Thanks Roger
Old Jan 14, 2007 | 04:53 PM
tomsrod's Avatar
tomsrod
Its Gemmer with a "G", the 375 is correct. It was used on F100 4x4, F250 4x4 and F350s. I'm not sure of the exact years though. It was also used on F600 and other medium trucks as well. I'm not sure of a source to rebuild yours. Most common salvage source might be the F350.
Old Jan 15, 2007 | 07:32 AM
sstrlh's Avatar
sstrlh
Just heard that 66-75 4x4 boxes are the same, can anybody confirm this. Thanks tomsrod, dont know where the demmer came from must be brain gas.
Old Jan 15, 2007 | 08:17 AM
fast frank 66's Avatar
fast frank 66
i bought a new steering box for my 2 wheel drive truck from carsteering.com here's a link for your's
http://www.carsteering.com/addtocart...artnumber~.asp
Old Jan 15, 2007 | 07:16 PM
garbz2's Avatar
garbz2
The 66 F100 box is differing from the 65 box in that it is not an integral steering shaft unit. It will not work on your application.
61 to 66 F250 4x4
61 to 65 F100 4x4
61 to 66 F350 2x4
Check NAPA they usually have rebuild kits for the Gemmer box.
Garbz
Old Jan 16, 2007 | 03:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by sstrlh
I have a 65 4x4 that i think has a Gemmer 375 steering box. I would like to find one to rebuild to save the down time of remove & rebuild. Anybody know what years these came in that would be a direct bolt up.
Thanks Roger
C3TZ-3504-S Steering Gear
1963/1966 F100/F250 4X4
1963/1966 F350 w/3.8M Axle
These^^were the only trucks to use this gear.
Old Jan 29, 2007 | 05:15 PM
Brian's Avatar
Brian
The later boxes do fit. I have two boxes off of 70's vintage trucks and use them interchangably. I had the original 66 box rebuilt and used the other boxes while it was gone. I have been experimenting with a grease packed box to eliminate the leaking of a fluid filled box. No apparent problems for the two or three years it was in service. I have a 66 f100 4x4.
jjreagan
Feb 21, 2014 04:30 AM
MRBARRY
May 25, 2012 01:12 PM
VEECON
Feb 1, 2010 10:03 AM
tealboy1
Jan 10, 2009 09:33 AM
unioncreek
May 29, 2002 11:12 PM
