Help determining rear end gear ratio.
Old May 26, 2002 | 10:55 PM
unioncreek's Avatar
unioncreek
I have just recently finished rebuilding my 390, I added a tach last week. At 60 mph tack reads 2750, I thought I had a 3.50 rear end. The formula I have says at that rpm with 27.75 inch tires that I have a 3.75. I jacked it up tonight and marked the drive shaft and tire and turned the tire one turn. The drive shaft turned 1 3/4 times, if I had a 3.75 shouldn't it have turned 3.75? I am probably not correct in my assumption so could someone correct me.
I would like to increase gas mileage and be turning about 2200 rpm's any comment on wanting to do this and the gear ratio I should use.
Thanks,
Bob
Old May 26, 2002 | 11:01 PM
Ratsmoker's Avatar
Ratsmoker
If you have an automatic tranny its kind of hard to say what gear you have due to slippage.
Old May 27, 2002 | 05:40 AM
jowilker's Avatar
jowilker
Bob, I can never remember to lift one wheel or both so I would suggest using your marks and rolling the truck along a very level spot of ground or floor. Have another adult with you to do the rolling while you watch and to be there just in case all doesn't go well.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old May 27, 2002 | 10:55 AM
Ratsmoker's Avatar
Ratsmoker
Memory is the first thing to go John! It's one wheel off the ground for a conventional and both for a posi rear.
Old May 28, 2002 | 07:28 PM
red68ranger's Avatar
red68ranger
With an open rear end and one wheel off the ground the turns ratio you observe is one-half the rear end ratio. 1.75 turns is the figure you should have gotten with a 3.50 rear end.
Dan Blackwell
(turned a wheel 18 times and saw the shaft turn 27--3.00 is twice 1.5)
Old May 29, 2002 | 05:45 AM
jowilker's Avatar
jowilker
I know that's right Sean, but rolling on the floor or very level ground should work for both types, right?
John
jowilker email me
Old May 29, 2002 | 06:53 AM
Ratsmoker's Avatar
Ratsmoker
Yep you are right John. Rolling it along the ground with the help of a buddy like you said is probably the easiest way. I do believe that one wheel off the ground will give you a 1:1 ratio. I have been wrong before but I'm pretty sure. I'll check it out for myself as I am currently changing out my diff gears within the next couple days.
Old May 29, 2002 | 07:15 AM
Ratsmoker's Avatar
Ratsmoker
Well forget about putting it to the test. I do believe you are right Dan. If you hold the driveshaft still on an open diff and turn the right wheel the left will spin at the exact same speed except the opposite way. If you let go of the drive shaft and hold the left wheel still the shaft should turn at 1/2 the ratio of the gear. Spinning both the wheels should give you full ratio.
Old May 29, 2002 | 08:34 PM
jowilker's Avatar
jowilker
Uh-Oh Sean's motor is sputtering, it's that memory thang.
John
jowilker email me
Old May 29, 2002 | 11:12 PM
big block power's Avatar
big block power
Don Vito
Nov 26, 2016 06:38 PM
capriceragtop
Aug 27, 2014 01:01 PM
benson az
2009 - 2014 F150
13
Oct 9, 2009 01:34 PM
Jacques
Jul 21, 2004 07:52 AM
gary534
Dec 1, 2002 08:55 PM
