Block Heater - Tripping My GFI
One thing to keep in mind here guys is this. Very few, almost no houses have single dedicated circuits anymore. Meaning that the GFCI is rated for 15 amps, however what else is on that circuit? It is probably wired with at least 3 outlets with it, and maybe some lights as well. A good upgrade for any home workshop is at least 1 dedicated 110 outlet with a 20 amp breaker. It will run any tools without tripping breakers. Another is to keep the garage seperate from any household wiring. Heck, the high frequency from my tig welder would set off my GFCI's in my old house, and it was fairly new wiring and met all codes.
As far as I know, the GFI outlet that I was having problems with has nothing else on it. The only other thing I have plugged into it is a trickle charger for my generator battery.
My house is kind of odd though. The guy that I bought it from is that one that had it built. My understanding is that he kept running out of money and firing contractors, so who knows who put one in. He also built the house so that there was a separate apartment in it for a relative; the house therefore has two furnaces and two fuse boxes.
I seem to recall when I had siding put on that the siding guys tripped it too, so it may just be a "weak" outlet.
Originally Posted by Beachbumcook
The block heater on the 6.0L PSd motor is +1,200 watts and maybe close to 1,300 watts (from memory). Have no idea what is on the gas version... but I would guess close to the same???
Originally Posted by BPofMD
Plug it into an outlet that does not have a GFI. If it doesn't trip the breaker, it's good. And I bet it's good!
Hootbro
There's a reason why all outside outlets, basement outlets, kitchen outlets, and bathroom outlets are GFI protected. Not just because the NEC didn't have anything better to do, either. Anytime you're working around a damp, or possibly wet location, you want to have GFI protection. All it takes is one person standing in water and accidentally touch the hot leg on an unprotected outlet before they get nailed pretty good.
Being an electrician myself, it's a pain in the butt to install GFI's in certain areas and get them to work right, but it's not a bad idea to have. What I think is bogus is the Arc Fault protection breakers, which will be mandated to be put throughout the house in the 2008 edition of the NEC, and not just in bedrooms. Those, folks, are a major pain.
Well....the block heater did work fine plugged into the non-GFI outlet. Could hear the gurgling this morning when I started it up, and warm air came out immediately.
Chad - I agree re: the reasons for the GFI. I will have an electrician replace the GFI that keeps tripping, as I am not very comfortable using a non-GFI outlet when the end of the cord is outside in the rain, ice, and snow.
Don't get me wrong. You're not going to burn down your house just because your block heater is plugged into a non protected outlet haha. I've seen some pretty crazy stuff, trust me, and this isn't even CLOSE to being a bad problem. And chances are, you're not going to get zapped. But that little chance is there, and I'd hate to see anyone get hurt.
If you lived close, I'd be over this weekend to change out that GFI for ya. But I have no idea where you live haha.
You may end up replacing your GFI outlet, just to experience the same thing if you don't zero in on the actual problem. They are designed to trip for a reason and you should rule out those possibilities. Not to sound silly, but if your bathroom GFI tripped while you grabbed the the radio while getting out of shower what you do?
Mark
#28
#29
Good one Beach! Anything but "Change the bad GFI" or "plug the radio into another outlet that is not protected"
Beach, as I know you use a Marinco plug also, remove the rubber boot behind it sometime and have a look. I was surprise how nasty mine was inside and the source of my problem I believe. In researching my problem, I did hear of some situations where the chord connection on the engine had a build up and was the source of the problem, so its best to assess/cleanup all connection points.
Mark
Mark
#30
I've not used my engine heater on my '03 F250 6.0L PSD, but my brother-in-law generally has to use his on his '95 F350 7.3L PSD whenever the temp drops into the 40's or below, or that 7.3 gets really hard to start. (new glow plug / relay, etc). He's got about 240K miles on it.
I've noticed that his extension cord running the heater block gets REALLY warm.
My guess like the others is that the GFI on that circuit wouldn't handle it.
rgds,
TX
rgds,
TX
