main bearings ????
Old Jan 13, 2007 | 04:31 PM
f2501967's Avatar
f2501967
main bearings ????
just got 390 from machine shop, with master rebuild kit. putting in main bearings, noticed oil holes not lining up properly, all holes in block are off center, all holes in bearings are in center. the bearing are clevette 77 all .010. this block was re-done from a 360 to a 390.
Old Jan 13, 2007 | 04:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old Jan 13, 2007 | 07:18 PM
shauk's Avatar
shauk
It's okay (and normal) that they don't line up exactly. Not sure exactly why, but it has something to do with the machining of the block. Use the shank end of a drill bit to ensure that the following opening is available in the appropriate oil holes:
1: 7/64
2: 9/64
3: 9/32
4: 5/32
5: 9/32
As per Steve Christ's "How to Rebuild Big Block Ford Engines" (which I'd highly recommend you'd pick up).
Old Jan 13, 2007 | 08:19 PM
f2501967's Avatar
f2501967
ty for the info, at least the bearing are only covering about 1/4 of the oil holes in block.
Old Jan 13, 2007 | 09:22 PM
baddad457's Avatar
baddad457
A die grinder and a porting bit will do wonders in aligning the holes. Just be sure to flush the metal out of the oil galleries before assembly.
Old Jan 13, 2007 | 09:38 PM
f2501967's Avatar
f2501967
baddad, just grind the block holes on an angle to line them up with the bearing oil holes???
Old Jan 13, 2007 | 10:02 PM
baddad457's Avatar
baddad457
Yea that's what I did on my last 390. I opened the passage from the pump to the filter mount up, and chamfered all the passage corners and the main bearing misalignment with a die grinder and porting bits. I also installed restrictors under the rocker stands.
Old Jan 13, 2007 | 10:12 PM
arctic y block's Avatar
arctic y block
AH HA a new use for the Robo Zip.
Old Jan 14, 2007 | 08:55 AM
baddad457's Avatar
baddad457
I don't know that all the effort (about an hour) made a difference, but it made me more confident about the oiling system.
Old Jan 14, 2007 | 12:36 PM
390fe's Avatar
390fe
Like baddad said, be sure to get the shavings out of the oiling system, or you'll destroy those new bearings when you start that 390.
The modification is not nesessary for a stock built engine. There are original 30+ year old 390's running around today with mis-matched oiling holes. When you start turning serious rpm's and making gobs of power, then maximizing the oiling system is key.
My opinion, of course...
Old Jan 14, 2007 | 01:19 PM
f2501967's Avatar
f2501967
this is basically a rebuilt stock 390, the only addition is a edelbrock cam at .494 lift with edelbrock intake and new double timing chain with a holley 2 bbl at 550 cfm
and also i want to thank all who have answered my question
Old Jan 14, 2007 | 07:11 PM
arctic y block
Sounds like a strong daily driver. Don't now much about cam specs but that seem high to me. Will it idle smooth? my 390 with 427 rotating assembly and RV type cam starts and idles while warming up. Than it flat hauls.
Old Jan 14, 2007 | 08:50 PM
460's Avatar
460
[hijack] Will this book clearly show me how to replace a rear main seal in my 390? [/hijack]
Old Jan 14, 2007 | 09:35 PM
f2501967's Avatar
f2501967
with this cam, it will rock the truck side to side, this is the same cam and top end i had on my 360 block. when im going down the highway it also flattens out. but with my dual exhaust with 45 deg turn down after the mufflers, u can hear me coming up and wave as i pass ya. lol
the only draw back is the low geared rear end. eventually this will be replaced at a later date. for now the gas mileage is only about 6-7mpg
Old Jan 15, 2007 | 03:04 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well actually those offset main hole's were made for a purpose..To restrict some of the lower end Oiling and keep it up on top at the shaft rockers and Valvetrain...
But with guys running upgraded Rockers and Valvetrain components of today, we dont need all that Oil on the top end..So the Bearings are either chamfered to let in more oil, Or the holes are opened up to keep more oiling to the Mains for High rpm motors, and motors that are drivin under harsh conditions!! Like me! LOL
RJ
