Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Anyone Replace Shocks and/or Struts Yet?
Old Jan 13, 2007 | 02:38 PM
tonyford's Avatar
tonyford
I checked mine for leaks while doing an oil change and no leaks found. Ride is stiff and cornering is excellent. Did the bounce test and front end came back up quickly and stayed there. 54K on odometer.
I have heard stories where the original shocks/struts have blown out well before 50K and had to be replaced. Sounds hard to believe, but I guess anything is possible.
Lots of people say that shocks/struts are a wear item, I have never replaced them in any late model vehicle I have owned or have known anyone to replace them unless they leaked.
Any comments?
Old Jan 13, 2007 | 04:34 PM
DoctorCAD's Avatar
DoctorCAD
Those are the kind of thing you never notice being bad until you change them.
Old Jan 14, 2007 | 08:19 PM
tcesni's Avatar
tcesni
I haven't replaced mine after 110,000 miles, quite a few of those while towing a 2200 lb boat. Frankly, I'm amazed that I cant' tell a bit of difference since I bought the car.
Old Jan 15, 2007 | 12:01 PM
DoctorCAD's Avatar
DoctorCAD
See My Post Above...
Old Jan 15, 2007 | 04:22 PM
tonyford's Avatar
tonyford
Originally Posted by DoctorCAD
Those are the kind of things you never notice being bad until you change them.
Maybe, but I think you would notice your shocks or struts needing changing before a routine swap out. If something really went wrong with them, I think you would notice it real fast.
Again, if it ain't broke, don't fix it..
Old Jan 15, 2007 | 04:57 PM
Ronin007's Avatar
Ronin007
The hard part with shocks or struts is that they wear out over time and is a gradual process so you don't really notice it. On the Super Duty forum people are always saying that after they installed this lift or that lift that the truck rides better than stock. That is debatable as when I installed my leveling kit after 50,000 miles my truck didn't bounce and my shocks were not leaking any oil, but when we took them off they were shot. My truck rides much better now, but in order to say better than stock I would have had to install the kit right after taking deliver of the truck to get a true comparison.
Old Jan 16, 2007 | 06:56 AM
DoctorCAD's Avatar
DoctorCAD
You'd notice a "broken" shock, but what you don't notice is the gradual wearing-out of these components.
I have a friend with a Ranger pick-up, when I get in that truck, he only has to hit one bump and I can tell the shocks are worn. he insists they are fine.
Old Jan 16, 2007 | 10:23 AM
tcesni's Avatar
tcesni
Shocks and struts do go gradually and can be hard to notice until replaced. Still, towing 2200 lbs. tends to make changes more noticeable.
Old Jan 16, 2007 | 11:36 AM
Ronin007's Avatar
Ronin007
Towing, haul any amount of weight, plowing, performance driving, or drive on a washboard road will tend to show worn out shocks or struts. The old bounce test doesn't seem to really work unless the shocks AND springs are shot, but by that time it is noticeable in the vehicle.
berry1234
Feb 2, 2017 07:50 PM
Cofcmsc
2004 - 2008 F150
Sep 15, 2012 08:07 PM
doublebutted
May 18, 2012 07:26 PM
keyul
General Automotive Discussion
Mar 23, 2008 09:08 PM
sullivanmar
Feb 26, 2002 02:18 PM
