Increase Fuel Mileage
Old Jan 13, 2007 | 01:59 AM
1978f150sc351m's Avatar
1978f150sc351m
I am about to rebuild my 78 F150s engine and I was wanting to get the best mileage I could out of it. I was getting about 12-13 mpg out of the 351M with 2.75 gears. While I am getting new engine parts, what upgrades could I get to increase the mileage? Should I go with a new cam, rockers, or what else? I also need the part # so I will know what to look for.
Old Jan 13, 2007 | 11:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Run the compression up to 9:1. Upgrade parts for a 351M are scarce. You may want to rebuild as a 400 to take advantage of those gears. Check with TMI for parts and options.
Old Jan 14, 2007 | 12:49 PM
pcmenten's Avatar
pcmenten
I would use a stock cam and degree it straight up. I think the stock tune on the carburetors were set to the rich side to reduce NOx production (and help keep the catalytic converter hot). Rejet the carb. If you're really serious about mileage, make sure the EGR systems is in place and working. The rich tune of the stock carb tended to gum up the EGR valves, so leaning the carb will help keep the EGR working. If you're not a believer in EGR, then make sure the advance of the distributor is tuned for a non-EGR engine.
There aren't many iron 4bb intakes for a 351M. I've seen where someone modified his iron 2bbl to make it a 4bbl. I don't know how hard it would be to get an iron intake welded to fit a 4bbl. It could cost $200-300.
Old Jan 14, 2007 | 03:53 PM
Bouts21's Avatar
Bouts21
I've got a 400 stroked .030 with some other goodies, I get 10mpg unloaded regardless of how I drive, hook up my travel trailer and I get 5mpg regardless of how I drive. Had the carb worked on and set up by a local garage with a good rep for carb work, and now I get 10mpg unloaded and 5mpg towing. I find the only way to get good gas mileage from the truck is not to run it at all. As for parts and advice so far the other posters are right on.
Old Jan 14, 2007 | 04:42 PM
grclark351's Avatar
grclark351
...a 400 stroked .030...?
Old Jan 14, 2007 | 05:00 PM
Bouts21's Avatar
Bouts21
lol bored lol
thanks for pointing out the error !!
Old Jan 14, 2007 | 08:54 PM
danlee's Avatar
danlee
Raising the CR will help some($$). Also running the cam straight up should help(cheap).
A good Sequential EFI setup shoulld also help($$$).
Old Jan 14, 2007 | 09:40 PM
havi's Avatar
havi
I'll have the Roast Duck
FWIW, in an emergency, I put my 74 F100's 302 2v carb on my 78 Bronco's 351M intake. What it did was shock me....I got a bit better mpg, and better throttle response. My 2 cents.
Old Jan 14, 2007 | 10:20 PM
grclark351's Avatar
grclark351
Bouts21, i was just curious what you have going on in there...
for a serious gas mileage build i'd do the 400 upgrade if the budget allows, with a Comp Cams 240H or 252H but watch the dynamic compression with these small cams if you plan on using TMI pistons. either a fresh stock carb and stock intake or an S.P.2.P. manifold with a Holley Economaster carb on it, and 2 > 1 single exhaust with a low restriction turbo muffler.
Old Jan 14, 2007 | 10:31 PM
Bdox's Avatar
Bdox
Here's an old, long, gas milage thread.
https://www.ford-trucks.com/forums/4...mpg.html?pp=15
plenty of bs but some really good stuff too.
Old Jan 15, 2007 | 02:49 AM
roger dowty's Avatar
roger dowty
i'll be building anoher 400 for a combo of mileage and power in my daughters (16 in aug) 70.5 falcon (torino body). It will have the typical 268-272 or so duration build with good compression etc. I also plan on putting a gear vendors over/underdrive and 3.25 or so gears so the final drive will get her 2500 rpm at 80mph. I am expecting that she will get over 20 hwy and still be able to kick some hiney at the 1/4 track. Hoping to get 380hp and 450ft lbs.
planning the build now...just got the weiand intake. From my research the 400 can make good power in an economic way. Gearing and weight is huge. Gotta say I'm still considering going with the alloy heads and getting her up over 400 ponies...well see.
jspringator
Dec 26, 2012 07:20 PM
offroad_guru
Sep 29, 2004 11:47 PM
Silver_Bullit
Sep 22, 2003 05:09 PM
RngrRcr
Sep 26, 2002 08:40 PM
orangeford
Oct 27, 2001 06:47 PM
