I recomend you to ...
Old Jan 12, 2007 | 04:54 PM
DJdemon6696's Avatar
DJdemon6696
Smile I recomend you to ...
Do a Trans Tune up change the fluid and filter and ! damn!! what a difference it shift realy smooth now and everyting... so do it
Old Jan 12, 2007 | 06:17 PM
quicklook2's Avatar
quicklook2
and of course you drained the torque convertor, right?
Old Jan 12, 2007 | 06:41 PM
DJdemon6696
yes of course, it was allot of work but worth it
Old Jan 12, 2007 | 07:29 PM
kell104's Avatar
kell104
Amazing what a little PM will do huh?
Old Jan 13, 2007 | 01:42 AM
grizz3000's Avatar
grizz3000
was thinking of draining tranny too but draining the converter? Hmmmm, is there a thread on that someplace?
Old Jan 13, 2007 | 03:27 AM
jroehl's Avatar
jroehl
It's not terribly hard. There's an inspection plate on the front of the bellhousing at the bottom. You remove that (probably have to remove the starter first), then you rotate the engine by hand (pull the coil wire first) until you can see the drain plug for the torque converter.
Jason
Old Jan 13, 2007 | 10:23 AM
gustang818's Avatar
gustang818
My '92 E4OD has a rubber plug on the bottom of the trans bell that is removed to access the drain plug in the converter.
Old Jan 13, 2007 | 10:42 AM
bigfootford's Avatar
bigfootford
And when you do it add one of these inline filters.
I did mine, you don't have to cut the line or anything. 10 min job.
Watch the torque on that TC drain plug. It's a tapered thread. Use teflon tape. I couldn't find a torque spec on the plug and didn't get it tight enough, had to remove the rubber inspection cover and tighten it some more.
Old Jan 13, 2007 | 09:57 PM
grizz3000's Avatar
grizz3000
Ah, okay, I think I understand. I've always wondered what that bell housing plate was for! Quite easy to remove on my C6 auto. Stared at it a lot during my rear seal job this past week or so. Sounds like a tranny drain is in my summer's schedule.
I have oil coming out of the bottom (from behind) of that plate though.
Old Jan 14, 2007 | 10:32 AM
gustang818's Avatar
gustang818
Probably your front seal on the transmission is bad.
Scramblermaster
Bronco II
37
Oct 1, 2011 06:02 PM
Racerguy
Aerostar
13
Aug 9, 2004 08:48 PM
Mike W
24
Sep 12, 2003 10:01 PM
motobub
User Gallery & Picture Display
Jan 9, 2003 01:16 PM
Pastmaster
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 21, 2000 08:13 PM
