7.3 deisel injector cleaner, etc
Old Jan 12, 2007 | 03:19 PM
robjs111's Avatar
robjs111
what is the best 7.3 injector and engine internal cleaner on the market. i was told that if u r running perf mods like a chip, etc theinjectors have to be kept very clean. makes sense. so what is best out there to get this done and should i use on every fill up? thanks.
Old Jan 12, 2007 | 03:24 PM
dcwhipple's Avatar
dcwhipple
I refer you to the DieselKleen - Wow! MPG?...unbelievable!! ( 1 2 3 4 ) thread a few posts down...
Old Jan 12, 2007 | 05:38 PM
Fat Diesel's Avatar
Fat Diesel
I'm of the belief that fuel at 20,000 psi getting shot through and injector keeps it pretty clean. Make sure you replace your fuel filter regularly and you'll be fine.
I've been running my injectors for 200,000 miles with only one failure. I put additive in it once or twice in that time.
Old Jan 12, 2007 | 05:45 PM
robjs111's Avatar
robjs111
r u running any mods like a chip, etc?? thanks.
Old Jan 12, 2007 | 06:09 PM
tjbeggs's Avatar
tjbeggs
DON"T RUN ANY INTERNAL CLEANERS!
A diesel engine is 100% cleaner inside than a gas engine. Diesel engine even after half a million miles don't have sludge build up. also these injectors are run from high pressure oil. anything other than diesel rated oil is BAD.
for fuel just run diesel Kleen, standyne, or biodiesel at about 5% mixture.
Old Jan 12, 2007 | 06:20 PM
CSIPSD's Avatar
CSIPSD
The best thing to clean your injectors is diesel, lots of it!!!
Old Jan 12, 2007 | 07:43 PM
CHPMustang's Avatar
CHPMustang
Smile
Howdy CSI I been using a cocktail blend of 25% Lucas/75% PSDK in every tank around .5 ounce total for every gallon of Diesel that goes in.
The combination has worked very well for us.
Old Jan 12, 2007 | 08:11 PM
CSIPSD's Avatar
CSIPSD
hey hey hey!!!
