Six Speed Transmission
Old Jan 11, 2007 | 06:40 PM
Gparcels's Avatar
Gparcels
Not to get to off topic here, but I know the 6 speed will get better gas mpg's, and the vehicle will be faster, but how will it handle towing a heavy load let's say above 5000lbs compared to the 4 speed thats out now. Not comparing the same but how would the current F150 stack up in towing againest a new exped. Just curious.
Old Jan 11, 2007 | 07:49 PM
Chris1450's Avatar
Chris1450
As usual ford will be the last player to market with a 6 sp. in a half ton truck, for 07 they have the weakest drivetrain in a truck!!!!!!!!!!!
______
what ever dude... go buy a chevy and leave in peace. your whinning is getting pretty old. If gm "pushes" ford with there new models, it is not because they are better. It is because of advertising and price cutting. AND fleet sales. Lowest bidder wins.. even at a profit loss for gm. (they have done this for years) All to get the numbers. That is the only reason they sell as many as they do. The 5.4 is still the tow king in half ton trucks. If you want fast, you should have bought a mustang GT. As it is you have a truck. I am also convinced, dispite what gas you SAY you use, that you use the cheap off brands. I really don't think your "carbon" problem is anything more than poor gas. There aren't that many people that have the problems your having. Out of 900,000 trucks sold a year by ford, the problem would show itself a LOT more than a few complaints on the internet.
Old Jan 11, 2007 | 07:53 PM
KrAzYKARL's Avatar
KrAzYKARL
So let 2007 be a "Enjoy what you have now" year. and hold out for the new 150s.
Old Jan 11, 2007 | 08:33 PM
Chris1450's Avatar
Chris1450
I have an idea that the 6 speed when availible in the F-150 will not have a tow rating that is as high as the 4 speed. I do believe that is why the 6 speed isn't availible now. ford will be making a BIG mistake if it takes the route of the other wannabe's and make a car out of there truck.
Old Jan 11, 2007 | 08:43 PM
WhëëlMå1's Avatar
WhëëlMå1
Well they offer a 6-speed manual in the Super Duties.... so why not a six-speed in the half tons (even if it is an auto). Efficiency is efficiency... no matter how you cut it. I am glad to see that Ford is adding more gears. If truckers can have 18 or more gears, why cant a regular truck have 6? I am not sure how this new tranny would effect the two rating. Why would it negatively impact the rating? If anything, it is allowing your rig to effectively manage its power to move a load EASIER with the extra gears.
Old Jan 11, 2007 | 09:06 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
______
You can suspect anything you want on the gas I use I have no reason in the world to lie to you, and on the carbon issue why do you suppose all these folks that are hitting 50-90K can't get their plugs out in a word CARBON BUILDUP read some of these other posts. Obviously you also don't ;understand trannys much either a 6 sp. likely will have a higher tow rating with the extra gears and probably will have a tow haul mode.
Old Jan 11, 2007 | 09:22 PM
Chris1450's Avatar
Chris1450
There are plenty of people using crap gas. That would explain the problems now wouldn't it? All these people? This is the internet where problems gather. This is no way an indication of most people. I am sorry you have such a low opinion of your truck. Maybe your being hyper critical? maybe you have a problem or two and now are gun shy? I don't know your story, but yours isn't the norm. A 6 speed won't have a higher torque rating. Your fitting more parts in the same size package. That will take away some durability. I am about sure that is why it isn't in the F-150 now. Ford will take a big hit if they put in that tranny and it doesn't have the same tow rating. The talk of fuel milage in a truck is pretty crazy. power and milage don't go hand in hand to well. Tow or milage??? hmmm... I have a truck... i will pick tow. BTW... I don't think I am doing to bad at 16 mpg mixed and 18.7 mpg on the hiway. Pretty good for a near 6000 lb truck. cheby can't do that according to mag reviews. Even with there cylinder deactivation.
Old Jan 11, 2007 | 09:36 PM
96f150's Avatar
96f150
(2 cents added here) I would think the 6speed Auto, will build up more heat, so the tow rating will be lower. The clutch packs will be close together in that transmission case don't forget. Example, look at how bullet-proof the C-6 was, and it was a 3 speed.
Old Jan 11, 2007 | 09:39 PM
04 FX4 Lineman
Well using your logic how is the new tundra getting 381 HP and 400 ft lbs of torque through their 6 spd tranny with a tow rating of I beleive around 10,500 lbs???? I am also getting about the same mileage you are I am a bit down now around 15 but think we are on winter gas because I have lost a little??
Old Jan 11, 2007 | 09:51 PM
the_webers_inc's Avatar
the_webers_inc
A mostly quiet Supporter
I rather doubt that you will lose any towing capacity by gaining more gears. And I don't think that we have to worry about a 6spd transmission being weaker than the current 4spd. IMO, having 6 speeds instead of 4 will improve performance & towing b/c you have more gear ratios closer together, putting power to the ground more efficiently, therefore boosting towing capacity if nothing else.
Too bad that they couldn't just use the Torque Shift Automatic transmission (5spd) from the Super duties. It's a tough Transmission and I'm sure that they can add another gear to it without too much trouble. I would love to have the tow/haul option in my F-150 instead of OD on/off. Oh well, one can dream......
In short, I think that when ford introduces a 6 speed auto in F-150's, it will be up to the task off out pulling the rest in its class.
T. J.
Old Jan 12, 2007 | 12:45 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I have to agree with 04FX4Lineman on this. the 6 gears will allow for deaper gearing of the "drive" gears and help manage engine power more effectively in the low rpms.
the tow rating should be the same, or go up a little. I also wouldn't be surprised if the rear gears get facelifted to a higher ratio (3.33 and 3.55) instead of what is offered right now (3.55 and 3.73). that 6th gear will be one heck of an overdrive.
as for transmission heat, if it really is an issue, they'll probly throw an external cooler in as standard equipment.
you can get power and mpg. my buddy gets 20+ mpg (city) with 495hp and 515 torque. with a six speed. I wouldn't expect this of a 6000lb truck, but it probably wouldn't be unreasonable to see 16-18 mpg (city) with an auto 6 speed
Old Jan 12, 2007 | 01:13 AM
the4by4freek's Avatar
the4by4freek
Ok.... A bit confused here! Why on gods green earth would you say that they will change the gearing to 3.33 and 3.55 only? Do you have any idea on how a transmission works? Or for that matter a differential? They could put 4:10 gearing in with a 6 speed trans and have a very capable tow vehicle. You would still have your low end power for towing and you would still have a great cruising RPM for fuel economy! Lock out OD or, if they do one better and offer a tow/ haul package and there wouldn't be a 1/2 ton on the market that could touch it! Slam in the new V6 Diesel that is in the works and the 6 speed and 4:10's and you would have one hell of a truck! It would pull a house, have decent fuel economy and still have the best styling on the road!
Old Jan 12, 2007 | 06:08 AM
  #28
96f150's Avatar
96f150
Bryan, put me in line for that v-6 diesel with 4.10LS, that would be great. I would think they would have to change over to the 10.25" sterling rear diff, as with the 9.75" rear doesn't have any geraing available over 4.10" I believe. Who knows, maybe a 6speed will work great. I can't see tow ratings going much higher than they are already. I would't want to put 10k behind my F150
Old Jan 12, 2007 | 02:23 PM
  #29
BruceFX4's Avatar
BruceFX4
You are logically assuming the 6 speed will be single or possible 2 OD transmission. If for some reason they decide to build the 6-speed with a 6th being 1:1, the axle gears could even go into 3.00:1 and give towing and economy gains. As long as we get better pulling/acceleration and better economy it is all good.
Old Jan 12, 2007 | 04:32 PM
  #30
the4by4freek
The F-150 HD offers a 4:10 diff ratio. I could see Ford offering this package realistically. Put me in line for one of these as well. I pull over 8000# on a regular basis and I love the truck. I do sometimes wish it had more power in the hills though. The trailer is 33' from tongue to tail. It tows great on flat ground.... 63-65 with cruise set. In the mountains the truck does work, but it could work less with a different driveline. I am still able to maintain speed, just in 2nd gear. As for the other post... we already got a 4 speed trans. If they lower all the gearing a bit and put in a decent final OD gear this would be great. For those of us that do tow, we could utilize 5 gears instead of 3 and the final outcome would be awesome! I still think that the best combo would be the PSD mated to an Allison trans. I am not a big fan of GM but the Allison Transmission is quite impressive. Much better than the outdated trans that Ford uses. JMHO!
