1966 - 1977 Early Broncos
engine diagnosis
Old Jan 10, 2007 | 06:48 PM
MrEli76's Avatar
MrEli76
engine diagnosis
Hey guys im trying to figure out why my 69 bronco is acting up while on the road. Its a 302, 3 speed on the floor. Problem is only when im driving on the fwy in 3rd gear it kind of feels like its puttering out when i get on it. I can keep the truck about 60 mph and if i try to go any faster it feels like it chokes out for a sec. while it backfires. Any ideas would help.
Thanks
Eli
Old Jan 10, 2007 | 09:04 PM
thefarelaneman's Avatar
thefarelaneman
I assume you have good plugs and wires etc.....How long since the carb was rebuilt or replaced? Also inspect the distributer advance and be sure there are no vacum leaks.
Old Jan 11, 2007 | 09:20 AM
RCrawler's Avatar
RCrawler
Only does it at highway speed? What is the condition of the basic tune up parts? Ignition timing correct? What carb does it have? Does it have points or electronic ignition? Does it backfire through carb or out of the exhaust? After it backfires, does it pick up and go like it is supposed to?
Jason
Old Jan 13, 2007 | 09:54 AM
Beechkid's Avatar
Beechkid
I would definitely look at the distributor very closely- check the advance, possible weak springs or the vacume assembly needs replacing. Also check the rotor, sometimes the fit onto the rotor shaft appears ok but it is not, causing the rotor to slightly rotate at certant constant speeds.
Old Jan 13, 2007 | 09:55 AM
Beechkid's Avatar
Beechkid
Also, if you are in Ca or a state that using blended fuel (10% methanol) try advancing your initial timing about 2-3 degrees.
Old Jan 22, 2007 | 07:56 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Install a fuel pressure gauge then road test
again. You positive the fuel pump is keeping up?
Fuel filters clogged up and can't flow at high fuel demands?
Cruising at 60 your mechanic should be all in,
getting on it hard your vacuum shouldn't be the problem.
bassmas5
13
Aug 14, 2017 05:42 AM
fdude64
Feb 10, 2011 10:16 PM
newBstroker
Jan 13, 2009 11:26 AM
wezol5484
19
Dec 20, 2008 08:56 AM
twillix5
1978 - 1996 Big Bronco
Feb 13, 2007 08:50 AM
