Sponsored by: Real Truck
Keyless Entry Code
Old Jan 9, 2007 | 11:38 PM
MasterBlaster's Avatar
MasterBlaster
Keyless Entry Code
I recently bought a used F-350 Lariet (2004) with the keyless entry keypad under the door handle. Where do I look to find the factory code? I want to put in my own code but I need the factory code first to make that happen.
Thanks for your help.
Old Jan 10, 2007 | 12:46 AM
donjamer's Avatar
donjamer
My 06 came with a Credit card that had it on it. Did you look in the owners manual (if you got one).
I looked in the manual and it said that the code is also on the computer module. Not sure where this is located, but I think it is in the drivers side kick panel..
I had a 88 Lincoln that had the code in a few different places on a white sticker.
Try looking in the glove box and also around the door frames...It is a 5 digit number..
You can also get it from a Ford dealer according to the book, but they probably just read it off the computer and charge you for it..
Hope this helps..
Old Jan 10, 2007 | 06:21 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Try this . . .
It is up under the dash, over the drive shaft hump under the radio area. It is approx 4"x3" and has the number printed on it w/o reference to what it is for. Suggest looking from the drivers side for it.
Do a search as this has been discussed several times and some posted pics of it.
cassenbl
Apr 7, 2015 12:33 PM
mgraveman
Feb 8, 2010 08:32 PM
F250dieselAROD
Aug 30, 2008 04:39 PM
excursion2001
General Automotive Discussion
Feb 9, 2004 10:10 AM
jbookrun
Dec 8, 2003 04:55 PM
