98 3.0 Running Lean
Old Jan 9, 2007 | 07:48 PM
Russ8393's Avatar
Russ8393
98 3.0 Running Lean
I changed my engine this weekend and now I have a check engine light coming on. The code reader tells me that it is the number 2 bank oxygen sensor and that it is getting a lean reading. The only other problem that I have noted is that sometimes the engine seems to be stalling. For example I will be going down the road and the engine seems to not have enough power and then all of a sudden you are pushed back in your seat. Then this morning on the way to work I was going up a hill and it started to lose power. Then I heard the engine back fire so I pulled off the road. The engine seemed to idle ok so I continued on. From then on it ran great. Please let me know what you think. Thank you, Russ
Old Jan 10, 2007 | 08:30 AM
freirefishing's Avatar
freirefishing
are u getting proper fuel milage for your engine swap.
Old Jan 10, 2007 | 07:24 PM
Russ8393's Avatar
Russ8393
I have not drove it far enough to really tell. But I don't think so.
Old Jan 10, 2007 | 07:31 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I'd be looking for a vacuum leak... possibly a gasket that split on you or a vacuum line disconnected...
Keep in mind just because you aren't getting a code for the other bank being lean, doesn't mean it isn't. It's very possible (and common) for one bank to be slightly leaner than the other, setting a code for one bank and leaving the other bank at a marginal, but acceptible, trim level.
I'd be taking a real close look at the fuel injector O-rings at the intake... sometimes they "roll" upon installation and cause a vacuum leak. I'm assuming those got swapped over into the new engine.
Good luck
Old Jan 10, 2007 | 07:49 PM
Russ8393's Avatar
Russ8393
I installed new o rings when I put in the injectors. How would you check for a vacuum leak? Also I changed the o2 sensor and had the codes cleared and they have not came back. This morning the engine did the same thing on the same hill. It just seems to lose power and I have to pull over. Then I can start again and it drives great. It drove good for the rest of the day. I did notice a slight hesitation a few times during the day but nothing bad.
Old Jan 10, 2007 | 08:41 PM
Wilber15's Avatar
Wilber15
When running at idle spray carb or brake spray around all the intake gaskets and vacuum lines and watch for an idle change. This will indicate a vacuum leak. Check fuel pressure too. Seems like you get your trouble under load? Could be to low of fuel pressure and it's being starved.... Do you have the ability to watch engine PIDs while driving?
Old Jan 15, 2007 | 05:30 PM
Russ8393's Avatar
Russ8393
Not sure what PID's are? I do have two codes now. P1151 and P1152. I have looked for vacuum leaks and still can't find any. The engine is still bucking when it is under a load. The idle seems to be a bit high also. It is hanging out at 1000rpms. Let me know what you think.
Thank You
leonharu
Jan 6, 2012 12:54 PM
adamss
Jul 7, 2009 05:18 PM
RapidRuss
56
Oct 31, 2007 12:27 AM
ct.russ
Mar 4, 2007 06:43 PM
