If I buy a hook up kit from isspro can I use a auto parts store tach or do I have to use a isspro tach or could it be used to hook up a stock one theres no wires for one on my truck? Thanks
Does your truck have a stock tach in the instrument cluster? If it does, they are not hard to fix, usually it is the sending unit on the IP gear cover.
Yes the year of the truck would be nice so would truck specs.........
Please guys fill out a signature......... FTE unfortunately does not separate the 6.9 and the 7.3 trucks so we need your specific truck info to help you.
Sorry about that I dont have a stock tach or any of the wiring. What i really would like to know is if the kit from isspro will wire a tach from autozone for a gasser or will I have to buy a isspro one? My truck is an 84 f250 with a 6.9.
Thanks
the ip gear covor is where you put your oil in look strait at the top of your motor when you open the hood. if your tach or sending unit is bad you cant just go find another tach out of another truck i tried the tach and sending units are matched.
