manual temp
Old Jan 8, 2007 | 08:11 PM
j tate's Avatar
j tate
manual temp
i was just wondering where is the best place to put the pickup for a manual temperature gauge on the 6.9 ?
Old Jan 8, 2007 | 08:14 PM
j tate's Avatar
j tate
i forgot to mention, i would like to keep the factory guage if i could.
Old Jan 8, 2007 | 10:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Look at the heater hose coming off the passenger side head.
You can go in the same port on the drivers side head after you remove the plug.
Old Jan 9, 2007 | 08:22 PM
j tate's Avatar
j tate
thanks dave for the responce, i kind of figured that would be the best place to locate it. i looked at the plug last night, just wanted to make sure. thanks again dave.
Old Jan 9, 2007 | 08:35 PM
Dave Sponaugle
Just fasten the lead to the temp gauge so it don't get into the steering column.
There is also a plug in the rear of the passenger side head that would work.
My stock gauge was so far off, I just removed the stock sending unit and installed mine there. I also added a mechanical gauge for oil pressure, removed the stock sending unit there as well. My amp meter has not moved in 20 years, so it was replaced with a volt gauge.
I can see a custom dash with all mechanical gauges is in my future.
The speedo, tach and fuel gauge is all I still use in my stock cluster.
Old Jan 10, 2007 | 05:55 PM
j tate's Avatar
j tate
thanks dave for the responce. yes all of my gauges act like they're crazy, im going to start with the temp and end with the volt. thanks for the help.
