Sponsored by: Real Truck
tachometer installation
Old Apr 26, 2004 | 05:45 PM
ford firsttimer's Avatar
ford firsttimer
Question tachometer installation
I have installed a tach in my truck which has a 460 with electronic ignition. There are 7 wires coming out of the distributor. Can someone tell me which one is used for the sender? It's an auto meter tach and is supposed to be hooked up to the negative side of the coil.
Old Apr 26, 2004 | 10:50 PM
Greg250's Avatar
Greg250
If I remember correctly, green is the trigger wire on a auto meter. Red is switched 12v +, white is lights, black is ground and green is for the tach signal. hook it up to the negative side of the coil to make it work.
Old Apr 27, 2004 | 07:22 AM
ford firsttimer
Thanks, greg 250, that's one side of the coin. Coming off the coil are three wires, one single (red) top of clip, and one double, (also red) as near as I can tell, bottom of clip. Putting a meter on these, all are showing 12v. with the ignition on. Do you have an idea of what is negative? Thanks for your help.
XLTRat
Jan 30, 2017 05:37 PM
Sandracer340
Aug 31, 2015 06:56 AM
FLJ
Electrical Systems/Wiring
May 30, 2009 04:01 AM
danny_g_76
1978 - 1996 Big Bronco
Nov 16, 2005 02:15 PM
5x5F150
Oct 6, 2005 07:11 AM
