4x4 to 2wd frame
Old Jan 8, 2007 | 08:51 AM
clintp's Avatar
clintp
4x4 to 2wd frame
I own a 1979 f-250 4x4 reg. cab. The truck had a poorly grafted on rear section (frame). The graft was a mistake for the guy who did it as he put it together with a twist. I also own a 2wd f-250 s/cab. I want to know if the running gear from the 4x4 will transfer to the good frame on the s/cab. I am a welder so I can handle quite a bit of fab work. If the frames are totally different I will take another lok at my plans. I plan to put a propane tank behind the seat and seal it off from the cab and vent it to the outside and keep the full box.
thanks, Clint
Old Jan 8, 2007 | 09:00 AM
79_250RangerLariat's Avatar
79_250RangerLariat
Your gonna be further ahead to find a good 4x4 frame and save your self ALOT of hassle and money. What do you need the LP tank for??
Old Jan 8, 2007 | 10:56 AM
Mil1ion's Avatar
Mil1ion
What year is the SC frame?......you never said.
Usually I tell people if they want a 4x4...Just buy a 4x4 because of all the work involved to create one.
but because you are a fabricator..I won't tell you that
Old Jan 8, 2007 | 10:17 PM
clintp's Avatar
clintp
Both trucks are 1979. Normally I would agree with you, but the 4x4 needs a frame and the s/c has a bad motor and a straight frame. The s/c was given to me for a little welding I did so this project is to salvage one truck out of two.
Old Jan 8, 2007 | 11:04 PM
scottie2hottie's Avatar
scottie2hottie
I have an 82 F100 with 78 leafs/axle welded up front. It's doable. Take your time and pay attention to detail. It will pay off in the long run.
Old Jan 9, 2007 | 06:30 AM
74 F100 351m's Avatar
74 F100 351m
Just redo the 4x4 frame and sale the 2x4 to inprove the 4x4.
Old Jan 9, 2007 | 04:14 PM
monckywrench's Avatar
monckywrench
These trucks are easy to strip down to the chassis in a few afternoons. Welders can play by a different set of rules, so might as well blow them both apart and park the chassis next to each other. All will then become clear.
You might even elect to go big-truck style and get two C-channels the right length, then use parts from the donor frames to do yours. You could have a seriously strong frame the length you want with the features you want.
Old Jan 9, 2007 | 06:57 PM
monckywrench
Here's a link to professional frame stretch pics:
http://www.morryde.com/pdfs/Chassis%20Stretch.pdf
It might be of help making one truck out of two. I'm also looking for similar info on customizing frame lengths and reinforcing them.
Old Jan 9, 2007 | 08:50 PM
ranger429's Avatar
ranger429
He does not need to stretch the frame. He wants to take the front axle out of the regular cab 4x4 an put it on the SC 4x2. I say go for it. If you have a welder it should not be that hard.
Old Jan 10, 2007 | 06:32 AM
74 F100 351m
Why not put the sc on the regular cab frame. I put a crew cab on a regular cab frame, have photos in gallery.
Old Jan 10, 2007 | 09:00 AM
clintp's Avatar
clintp
reg s/cab
The reg cab frame was pretty well wrecked by the guy who modified it .It will be easier to move the front running gear to the straight s/cab frame. I am looking forward to having both cabs off so I can do a side by side comparison.
Old Jan 11, 2007 | 12:46 AM
74 F100 351m
I don't have a photo of the rear cab mounts But s/cab and crew cabs the mounts are on the outside of the frame. I found out that there is another hole under the crew cab that will let you put the rear mounts inside the frame like a reg cab. I don't know if this the same for the s/cab. I had to cut a hole on the inside for the bolts to go through. IF you're going to swap cabs.
Old Jan 11, 2007 | 11:25 AM
MuddinF2501999's Avatar
MuddinF2501999
Where are you located? Im looking for a solid 2wd rollin chasis and possibly a whole 2wd truck. I have a 4x4 '79 F250 as well. My frame is junk though, its very rusted and pitted from the original owner....
Im in TX near Houston...
MAN_N_BLACK
May 7, 2014 08:27 PM
masterbeavis
Jul 16, 2013 12:05 AM
EZFEED
Jan 16, 2010 09:36 PM
duste
Jan 3, 2010 06:16 PM
