Cheap cam upgrade possibly...
Old Jan 8, 2007 | 05:09 AM
Jrock909's Avatar
Jrock909
This would be worth the money at $35 for this cam right guys? Looking for something cheap to put in the ole 302EFI motor in my truck... It's a 92 F-150 302EFI with the base roller cam in it? Does gas mileage suffer from putting a upgraded cam in our 92-96 F-Series trucks also?
http://cgi.ebay.com/ebaymotors/Cam-c...70052409QQrdZ1
Old Jan 8, 2007 | 08:22 AM
Conanski's Avatar
Conanski
Yes, that cam works nice, it's similar to the '94-on truck roller. The gas milage you get is directly proportional to the throttle position, obviously.
Old Jan 8, 2007 | 08:29 AM
P51D Mustang's Avatar
P51D Mustang
I doubt that it will make a noticable negative difference in MPG. It might actually improve, depending on how you drive it?
On edit: The HO cam should be used with 1.7 rockers to better realize the potential improvement in power.
Old Jan 8, 2007 | 06:26 PM
Jrock909's Avatar
Jrock909
Mustang,
Do I need to buy aftermarket valve covers if I use those 1.7 Roller Rockers...? Are those Roller Rockers a direct bolt on also? Would you please give me a link to the best kit for those roller rockers that really does sound like the best way to go... HO cam with 1.7 roller rockers!
Thanks again,
Jason
Old Jan 8, 2007 | 07:24 PM
baddad457's Avatar
baddad457
Before buying or bidding on that cam ask the seller how many miles were on the engine it came from.
Old Jan 9, 2007 | 09:23 AM
P51D Mustang
Originally Posted by Jrock909
Mustang,
Thanks again,
Jason
The pedalstal mount 1.7 roller rockers from Ford Racing/Crane and Crane Energizer are a direct bolt on swap, and shouldn't need taller valve covers.
Old Jan 9, 2007 | 03:15 PM
baddad457's Avatar
baddad457
Shouldn't, but that depends on the covers. I've used the O.E. Cobra rockers with 83-85 Stang finned aluminum covers and had them bump the filler baffles in two sets. The Cobra 5.0 came with sandwich type, black painted steel covers from what I've read in Ford's 5.0 book. I have two sets of these but never tried them to see if they work. They sure look like they wouldn't, they look to be no taller than the old 289 Hi-po covers.
Old Jan 9, 2007 | 03:24 PM
Jrock909's Avatar
Jrock909
Baddad I asked the guy on ebay and he said 100,000+ on the cam and I found another cam on ebay which is the same and it had 130,000 on the motor with the cam in it? Do you have any 1.7 roller rockers lying around that you are wanting to sell that would work good on my 92 F-150?
Old Jan 9, 2007 | 07:29 PM
P51D Mustang
The Cobra valve covers arn't very tall, about the same as EFI HO covers, but they were used with the Ford/Crane pedalstal mount rollers. When we installed stud mount rockers, the Cobra covers wouldn't work anymore, but they seemed fine with the pedalstal mount.
Old Jan 9, 2007 | 07:35 PM
P51D Mustang
Roller cams don't wear out at the same rate as regular cams, due to the roller tappets and the metalurgy. They will usually show very little wear even at 200K. Unless, they have been damaged by a bad roller lifter, or abuse, or poor oiling..ect...then they would still be fine, even with high miles.
Old Jan 9, 2007 | 11:34 PM
baddad457's Avatar
baddad457
No roller rockers but do have a couple HO roller cams, one has less than 100K on it from an 88 Lincoln Town Car.
Old Jan 9, 2007 | 11:45 PM
Jrock909's Avatar
Jrock909
Baddad you think if I yank my stock roller cam and put a HO cam and some roller rockers I will feel a nice difference in power? Just asking if it is worth all the trouble that's all!!! How much for the low mileage HO roller cam?
L8er man,
Jason
craigibc
Aug 15, 2010 10:14 PM
mvvette97
15
Feb 25, 2007 06:01 PM
Jrock909
Dec 22, 2006 10:07 AM
Show-N-Go LX
32
Nov 29, 2005 10:59 AM
FordTrucks4Life
Jul 17, 2005 05:19 AM
