Sponsored by: Real Truck
Camper with snowplow package?
Old Jan 7, 2007 | 08:35 PM
billtrev's Avatar
billtrev
I have a depsoit on a 2005 F-350 SC SB 6.0 with the snowplow package. One of the main reasons that I'm moving up to a one ton truck from my '99 250LD is that I plan on using a "lightweight" slide-on camper (about 2000lbs) with it.
Other than adding a rear swaybar and maybe airbags should I be concerned that the truck doesn't have the camper package?
Old Jan 7, 2007 | 11:12 PM
wlihntr's Avatar
wlihntr
no, the snow plow package actually gives you the highest weight rated front springs (one step above what you get with the camper or heavy service packages) and everything else is the same
Old Jan 8, 2007 | 06:07 AM
HeavyAssault's Avatar
HeavyAssault
When I built my truck, the only difference is the piece of paper from Ford that says I can carry a camper.
Old Jan 8, 2007 | 06:51 AM
Leader's Avatar
Leader
If thats the only reason, keep your 99. It will handle that "camper" just fine.
Old Jan 8, 2007 | 08:15 AM
cmpd1781's Avatar
cmpd1781
billtrev, your F250 is fine. I have a 2000 that did NOT come equiped with any kind of Ford manufacturing "camper package"....just had a Lance Camper guy put on the happy-jac attachments and sway bar. Did the electrical attachment at front of bed too.......It carries a "lightweight" Lance (about 2000 lb) just fine..........
Old Jan 8, 2007 | 09:20 AM
redford's Avatar
redford
FTE Leadership Emeritus
The camper package consists of the Heavy Service Front Springs, Rear Stabilizer Bar, Slide-In camper certification and Rear Aux Springs.
The Snow Plow Prep package has all of that except the certification and rear stabilizer bar.
Old Jan 8, 2007 | 09:42 AM
454mag's Avatar
454mag
My 06 f-250 with plow prep package has a note in the glove box that this truck is not certified to carry a camper. Redford -- thanks for the info --looks like i need a rear stabilizer.
Old Jan 8, 2007 | 05:02 PM
billtrev's Avatar
billtrev
Well thanks for the replies everyone.
Does anyone see any warrenty issues with this?
Leader, While I'm sure the the '99 LD would be able to carry the camper, I'm guessing I would be about 700 to 1000 lbs overweight.(2300lbs payload vs 2000lbs dry camper + passengers, gear, food, water, propane, ect.) If it were a Super Duty I would be much more comfortable with it. With the LD I'm concerned that I'll be at or over the rear GAWR, plus its a great excuess to get a F-350 diesel!
