Cold start question
Old Jan 7, 2007 | 06:25 PM
a-rod's Avatar
a-rod
Cold start question
Anymore when I start my truck up in the mornings, with the temp being anywhere from -10 - 20 degrees, its sounding pretty rough. Right when it fires the RPMs jump way up and then back down and it kinda sputters and idles rough for a few seconds, Its even done it being plugged in. Running motorcraft 10W30 and an additive. Stock Flash. Should I just take it down to the dealership and try and get the new reflash? Or could this possibly be injector issues. Thanks for any advice. Adam
Old Jan 7, 2007 | 06:54 PM
vloney's Avatar
vloney
If it clears up after a few seconds, I would say sticky injectors. Get that new flash.
Old Jan 7, 2007 | 09:35 PM
BowTieHatr's Avatar
BowTieHatr
what kind of oil additve are you using?
Old Jan 8, 2007 | 08:43 AM
a-rod's Avatar
a-rod
Fuel additive power service, no oil additive, guess I kinda typed that wrong
Old Jan 8, 2007 | 11:13 AM
BowTieHatr's Avatar
BowTieHatr
okay i was curious because it sounded like you used an oil additve. it does sound like sticky injectors.
Old Jan 8, 2007 | 06:28 PM
a-rod's Avatar
a-rod
Is there anything you can do about sticking injectors? Or do they pretty much have to be replaced? Cant beleive they might be sticking, Ive always tried to use good fuel and fuel additives...oh well
Old Jan 8, 2007 | 06:31 PM
vloney's Avatar
vloney
Post #2----get the new flash
Old Jan 8, 2007 | 09:06 PM
a-rod's Avatar
a-rod
Somewhere I read that the flash is just sort of a cover up for sticking injectors, True? False? I think I am gonna try and get the flash though.
Old Jan 8, 2007 | 09:13 PM
vloney's Avatar
vloney
cover up or not, it works!
