Axle / differential question.
Old Jan 6, 2007 | 09:17 PM
SPL Tech's Avatar
SPL Tech
First of all what type of differentials are in the 2002 V-10 Excursion Limiteds? Limited slip or open?
Second who makes the rear axle? I need to know the actual weight limit of the front and rear axle.
I looked at the specifications here:
http://www.hillerford.com/Web%20Pages/resource%20library/2000/2000suv/00excursion.pdf
It says the max load for the rear axle is 7000 lbs. and 5200 for the front (4x4 models). But on page 34 it says the rear axle is rated for 6830 lbs.
So I need to contact the manufacturer of the axle to find out for sure. Contact information would be nice.
Old Jan 6, 2007 | 10:01 PM
3KIDDAD's Avatar
3KIDDAD
FRONT - DANA 60 HI-PINION -35 SPLINE AXLES
REAR - FORD STERLING 10.5"
Hope that helps...
I believe it's the same for all model years and all engine types.
Old Jan 6, 2007 | 10:13 PM
SPL Tech's Avatar
SPL Tech
Someone else on this forum said its a Dana 50 upfront. So is it a 60 or 50?
Old Jan 6, 2007 | 10:41 PM
housedad's Avatar
housedad
OK-
All excursions, all years, have a Dana 50 axle. Ford NEVER offered or put in anything else on the EXCURSIONS. Never. Period. No Way.
I have paper copies of every source book, owners manuals, Ordering book, Brochure, Accessories book, and accessories list that was made for all years of the Excursion. I have them right here.
All years, all models of Excursions have Ford 10.50 rear axles.
The Dana 50 axles themeselves are rated for 5200lbs
The Ford rear axles themeselves are rated ro 7000lbs.
Looking at the printed source book on page 31, it says 7000lbs, not 6830. The 6830 is obviously a misprint on the webpage.
I would like to clarify one thing for you. Whatever the axle itself is rated for, it is NOT the TRUCK axle rating. The front or rear axle rating for the truck is determined by Ford and is based on the parts that have the lowest capacity. It could be brakes, lug nuts, wheels, tires, springs, frame, or whatever. They are the only ones that know for absolutely sure. The factory truck axle rating is far less than the the excursions axles can handle.
We can take some very educated guesses at it, and we do. Ford designers admitted that they derated the springs to give a softer ride. This indicates that it could carry more safely. To be able to do so, you would need to change the springs to onws with a hight=er rating, or supplement them with airbags or helper springs. Since all other parts in the suspension are the same, and it has a very robust frame, if you were to change the springs, we change them out to the ford F250/350 springs, which have weight ratings that correspond exacly to the weight ratings of the axles. The Famous V & B codes with f350 riser blocks.
Old Jan 6, 2007 | 10:57 PM
SPL Tech's Avatar
SPL Tech
housedad I sent you a pm.
Old Jan 6, 2007 | 11:35 PM
3KIDDAD's Avatar
3KIDDAD
2000 - 2001 Used the Dana 50 front axle
2002 - 2005 Used the Dana 60 front axle
My understanding is Limited Slip was not standard on any model it was an added option for all models.
Old Jan 7, 2007 | 12:27 AM
housedad's Avatar
housedad
Sorry 3kiddad, but it was the ford Superduty pickups that changed to a Dana 60, not the Excursions. I wish I had a Dana 60. But I had to install a ring and pinion set for a dana 50 when I upgraded to 4.30's.
Mine is a 2005.
Old Jan 7, 2007 | 01:53 AM
SPL Tech's Avatar
SPL Tech
Well darnit is it the 50 or 60. everyone says something different. I have never even heard of a 50. I thought it went 30, 35, 44, 60, 70, 80, 90? How much better is the 60 over the 50?
Old Jan 7, 2007 | 02:09 AM
rikosintie's Avatar
rikosintie
I did 4.88s on my '02 V10 and the front was a Dana 50. If I remember right it limited the choices I had on a limited slip. I ended up going with an ARB Locker.
Michael
Old Jan 7, 2007 | 07:17 AM
sewerat's Avatar
sewerat
Housedad while we are on the subject, i can kinda read the tags on my diffs but i am trying to figure out what gears i have, i am assuming it is still stock, i am pretty sure the the rear one had some stuff that made me think 4.30 but that didn't seem right to me. is there a listing for what the tags will read and what they mean is inside?
thanks
craig
Old Jan 7, 2007 | 10:58 AM
Monsta's Avatar
Monsta
Sit. Stay.
You door jamb label should have the axle code. Axle codes are posted in my Super Duty FAQ that is stickied on top of the Super Duty forum.
housedad is 100%. Excursions never had Dana 60s. Only Dana 50s which have necked down half-shafts and a different spline count fron the 60 if I remember correctly.
Also, axle rating are posted on that same door jamb label.
Old Jan 7, 2007 | 01:12 PM
sewerat's Avatar
sewerat
ok so i find the sticker on the door jam, it gives me everything except the axel code, that spot is blank, figures just my luck.
Old Jan 7, 2007 | 07:34 PM
housedad's Avatar
housedad
Block the front wheels, jack up the rear, mark the edge of a tire with chalk, put it in neutral.
Mark a spot on the driveshaft with chalk.
Rotate the tire one full revolution and count the turns and partial turn on the driveshaft. That will be your ratio.
Old Jan 7, 2007 | 07:38 PM
housedad's Avatar
housedad
Can you read the metal tags and tell me what the say?
Old Jan 7, 2007 | 07:40 PM
sewerat's Avatar
sewerat
I know i can read one of them, i will crawl under it tommorow and find out, it's dark and wet out right now
